Cisco aironet 1131AG AP radio interface down
Hi ,
i have a problem with the radio interface of my cisco aironet 1131ag AP .
i have configured the ssid , authentication method , encryptation and i have associated it (the ssid) to the radio interface , but the dot11radio interface still in reset status , and if a restart the interface this msg appears " %DOT11-4-NO_SSID: No SSID configured. Dot11Radio0 not started " what i have to do ?
Please help
Configuration :
Building configuration...
Current configuration : 1394 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$URAK$Mf3YfBFQQS2.6MSWHQOeG0
no aaa new-model
ip domain name Nida.local
dot11 ssid Nida
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 01100F175804575D72
   admit-traffic
power inline negotiation prestandard source
username Cisco privilege 15 password 7 123A0C041104
bridge irb
interface Dot11Radio0
 ip address 192.168.1.80 255.255.255.0
 no ip route-cache
 encryption mode ciphers tkip
 encryption vlan 1 mode ciphers tkip
 ssid Nida
station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface FastEthernet0
 ip address 192.168.1.81 255.255.255.0
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address dhcp client-id FastEthernet0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
  • Getting Started with Wireless
Everyone's tags (1)
1 ACCEPTED SOLUTION
You should create the
You should create the dot11radio0.1 and fastethernet0.1 interface
Should be something like this:
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 ssid Nida
   vlan 1
   authentication open
   guest-mode
   admit-traffic
bridge irb
 no ip route-cache
 ssid Nida
 station-role root
interface dot11radio0.1
 encapsulation dot1q 1 native
 bridge-group 1
  no ip route-cache
 duplex auto
 speed auto
interface Fastethernet0.1
 bridge-group 1
interface BVI1
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
PS also removed the ip address under de dot11 interface and im not sure why the station role is root ?
I read something before about
I read something before about this issue.  Does this AP have a power injector?
No ,just connected to POE
No ,
just connected to POE switch .
Try putting the SSID under
Try putting the SSID under the radio interface.
Hi Earl , it is already under
Hi Earl ,
it is already under the radio interface
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 ssid Nida
   vlan 1
   authentication open
   guest-mode
   admit-traffic
bridge irb
 no ip route-cache
 ssid Nida
 station-role root
 bridge-group 1
  no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
it works , thanks  i
it works , thanks
i appreciate you help Marc and Earl
251
