Community Member
Cisco Aironet 1200 series ( AIR-LAP1231G-E-K9 )
hi there,
I have this wireless access point but i cant configure it.
I can see the boot with the hyper-terminal windows (xp), the ip adress is 219.1.1.179 (dhcp) but i cant go on with IE or Firefox.
When im on a console text (AP#) and want to configure terminal (i've tried conf term, conf terminal, config terminal and configure terminal) it doesnt works.
So i cant configure my access point.
(apologie my english :) Thanks for your help.
Community Member
Re: Cisco Aironet 1200 series ( AIR-LAP1231G-E-K9 )
hello,
it is better u configure static IP address for your AP and here is the Procedure.
ap>en (u should provide enable password by default is Cisco with Capital C)
ap#conf t
ap(config)#int BVI 1
ap(config-if)#ip add 10.0.0.1 255.255.255.0 (any ip address which u want to configure with subnet mask).
after this u can access ur AP interface in ur browser whith the same ip which u configure.
anyways can u write what is error it gaves when u write conf t.
Hall of Fame Super Red
Hi Emmanuel,
The problem here is that the model you are using ( AIR-LAP1231G-E-K9 )
is a Lightweight or LWAPP AP not an Autonomous AP that can be configured using the method you are trying. This is a very common problem that should be quite fixable :)
Here is the related info :)
Using a TFTP Server to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Hope this helps!
Rob
PS: your English is just fine my friend!
1363
