Cisco Aironet 1300 Series Outdoor Access Point or Bridge
We had an Aironet 1300 series and it only operates as an access point even do the location of this device is outdoor.Can anybody help me to configure this device as a bridge so that we can use its full functionality and capability.And if it is posible pls send me the configuration.
thanks alot.
Silver
Re: Cisco Aironet 1300 Series Outdoor Access Point or Bridge
A 1300 series bridge runs a very similar version of code that exists on access points, which allows the device to be configured as either a bridge or an access point.
Look at your configuration under "Dot11Radio0". You should see a command along the lines of "station-role XXXXX", where XXXXX can be either access point or root bridge modes. Make sure this says "station-role root bridge". The other end should be configured as "station-role non-root bridge".
Also, under your SSID, ensure that the "infrastructure-mode" command is used.
If you can attach your configuration, we could assist you further.
I already attached the file.
Hope you can help me and Thank you so much.
403
