Cisco Aironet 1602E i Cant get it to send AP signal
I'm a little on it. I just bought 3 * Cisco Aironet 1602e.
I can easily get into them and put them with the IP they must have on the network. But I can not get them to broadcast the signal out so i can see ith SSID on my phone or computer. I've looked through many guides and I can not find any solution on how to do it.
The 3 Access Point sits in a Cisco Small Business Smart SG200-26P which can provide PoE so it works: D
But how do I get the Access Point here to send a signal.
  • Getting Started with Wireless
VIP Purple
Did you check this post:http:
http://rscciew.wordpress.com/2014/05/24/multiple-ssid-configurations-on-autonomous-ap/
Here is the config
Here is the config
VIP Purple
Hi,Configure these parameter:
dot11 ssid TUC11
   vlan XX
   guest-mode
   authentication open
interface Dot11Radio0
 ssid TUC11
interface Dot11Radio0.XX
encapsulation dot1Q XX
 int Gig 0.XX
Ip default-gateway IP.IP.IP.IP
Here XX is vlan number.
Also chekc this post: http://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
Dont forget to rate helpful posts
As i say its my first time.
As i say its my first time. How do i find the vlan number i need to use. I can see you use 81 but some ppl use 10
VIP Purple
where did you connect to your
where did you connect to your AP (to swicth or ????)
VIP Purple
Configure these parameter:---
dot11 ssid TUC11
   vlan 1
   guest-mode
   authentication open
 ssid TUC11
interface Dot11Radio0.1
encapsulation dot1Q 1
 int Gig 0.1
interface BVI1
 ip address 192.168.0.11 255.255.255.0
Ip default-gateway 192.168.0.25
Okay i got my phone on now.
Okay i got my phone on now. But i only works when my phone is max 1 meter from accespoint. That is the first thing.
What can i do with the range of the network.
I also active 5G network?
And when i need the other accespoint up then with same SSID id what do i need to do more so it works.
I have read something with
I have read something with the channels if i will go after same SSID.
And then the range is realy bad so what can i do to make it better.
63
