Cisco Aironet 3702i Channel Size Issue
I just recently purchased an Aironet 3702i which I have running in autonomous mode.  When I attempt to set the channel width on my 5GHZ 802.11ac radio to 80mhz, nothing can find the AP.  I will post my current configuration below.  Any idea what I'm doing wrong?
Current configuration : 4254 bytes
! Last configuration change at 08:22:26 UTC Mon Mar 1 1993 by josh
version 15.2
no service pad
service password-encryption
hostname TARDIS_MARK_3
logging rate-limit console 9
enable secret 5 $1$991A$9UMPLnilNi4FZioIKaPuQ1
no aaa new-model
no ip cef
ip domain name tardis.local
dot11 syslog
dot11 ssid The Tardis 2.4GHZ
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 052C272328424F584954434A525E5C7A7B65
dot11 ssid The Tardis 5GHZ
   authentication open
   guest-mode
dot11 guest
crypto pki trustpoint TP-self-signed-1962918778
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1962918778
revocation-check none
rsakeypair TP-self-signed-1962918778
crypto pki certificate chain TP-self-signed-1962918778
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31393632 39313837 3738301E 170D3933 30333031 30363038
  34335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 39363239
  31383737 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B172 6239E092 598B148C 0EBE092B 786F380A 55BFB28B 37282B0F 2216B80F
  4065D3A0 2F5A7A14 7DF5AA0E A90C57E6 74BE3F84 FDEE04D6 C444442D CAFF16D5
  3A524471 18456C87 0AEFF7F3 F260FC04 9D2B9DF0 F2ECC976 2CBBF9BC 9DF8532F
  DF2BAFF0 9C5D4914 9B1A791C EDAF23A1 486535A7 DEAFF472 B0A3D034 3B397F90
  DEFD0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 142B888C 7EF2C64C 386A4875 F5F285F4 92CBE338 97301D06
  03551D0E 04160414 2B888C7E F2C64C38 6A4875F5 F285F492 CBE33897 300D0609
  2A864886 F70D0101 05050003 818100AB 64074D0D 7F2900C4 585062C0 DEFCFA9F
  7AFCC7BA CC26EB18 2FA5942D 20167E99 B505B6DD 07B92859 F3F411E9 093764C7
  BBABE9B3 47DCFFA3 18C7B9F9 6BE390E4 F06ED93B 31F9E8C7 7C3FD7C4 C147CF98
  C7FC4D5C 25CA3433 E209E03E 48552444 18DDBE5E EEEA6136 6C7920D3 2A7D2B51
  3C9192AD 60573FD2 9A290E13 483D19
            quit
username josh privilege 15 secret 5 $1$9Ng9$4HFWSEWP6LtKukx2YSIcy1
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
antenna gain 0
stbc
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
antenna gain 0
peakdetect
dfs band 3 block
stbc
speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss9 a3ss9
channel width 40-above
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
ip address 192.168.1.100 255.255.255.0
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input ssh
transport output ssh
line vty 5 15
login
transport input ssh
end
1 ACCEPTED SOLUTION
VIP Purple
Re: Cisco Aironet 3702i Channel Size Issue
Hi Joshua,
During beta testing I had the same issue & thought it was due to beta code. Now it looks like how cisco wanted it to behave, As per the published document given here, 3700 autonomous mode only support limited features & cisco suggest to use it for site survey purposes only. Below from this release notes of 15.2(4)jB3a
The 3700 series access point is supported only in site survey mode. You can install Cisco IOS Release 15.2(4)JB3a on Cisco Aironet 3700 Series access points to perform site surveys. This release runs on these access points with limited functionality. You can manually adjust these settings on the site-survey access points:
•Channel on each radio
•Transmit power on each radio
•Enable and disable the radios
•Manually set basic and supported transmit rates
•Enable advertised cell power in beacons to client to enable DTPC for doing active surveys
•Enable and disable SSID broadcast in beacons
•Enable open authentication
So no wireless 802.11ac client support in this (at least for now)
Rasika
**** Pls rate all useful responses *****
Let me correct that:  My 802.11n devices can see it by my 802.11ac devices cannot.
VIP Purple
Hi Joshua,
Rasika
I have a 3700 in with this
I have a 3700 in with this iOS config mode with the role set to access-point and an SSID 'survey' configured.  I'm not able to see the SSID when the radios are enabled though.  How specifically or where specifically is the setting to enable/disable SSID broadcast?
There has to be a simple way to do this, but am not able to figure out how to broadcast the SSID.  Any help is greatly appreciated???
VIP Purple
Below is the basic config you
Below is the basic config you required on your autonomous AP. Guest mode is the keyword under SSID config to make that SSID visible.
conf t
hostname <AP_HOSTNAME>
dot11 ssid <SSID_NAME>
   authentication open
   guest-mode
   wpa-psk ascii <SSID_PASSWORD>
 ssid <SSID_NAME>
 no shutdown
 channel width 80 <- if you require 802.11ac to be tested
 ssid <SSID_NAME>
 no shutdown
interface BVI1
 ip address dhcp
end
write memory
Rasika
One more thing; I'm not
One more thing; I'm not seeing DHCP config options.  Is there a way to allow clients to obtain a DHCP address from this 3700 in autonomous / iOS mode?
VIP Purple
Yes, In the above config
Yes, In the above config example you have to plug AP to DHCP enable switchport in order client to get IP.
You can configure DHCP on your AP. In the below, I have assumed 192.168.20.254 is the SVI defined on your switch for  vlan 20 and first 200 IP allocated for the DHCP pool. Make sure AP connected to vlan 20 switchport. (usually below config would be on your switch where you define SVI 20 unless you use proper DHCP server)
ip dhcp excluded-address 192.168.20.201 192.168.20.254
ip dhcp pool VLAN20
 network 192.168.20.0 255.255.255.0
 dns-server x.x.x.x
 default-router 192.168.20.254
Rasika
Did you ever get this fixed
Did you ever get this fixed ?
I seem to have the exact same issue: 802.11n client see the network and associate, but of course only using 40MHz. And 802.11ac client can't see the network at all. And if I reconfigure it to 40 MHz only, then both can see and connect (and the 802.11ac client will use aX.Y data rates, but on a 40MHz channel only).
Even though in another topic someone reported connecting 802.11ac client to a 80 MHz channel using the latest 15.2(4)jB4 IOS (which I'm using).
Hall of Fame Super Silver
The IOS code for the 3700's
The IOS code for the 3700's are still only for site surveys and the use of 80mhz channels for site surveys isn't really being used.  Until Cisco decides to support the 3700's in IOS, you will be out of luck using 80mhz channel width.  If you had a WLC, it does work, I can tell you that:)
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
I know that full officially
I know that full officially supported autonomous config for 3700 will only be out in a few month according to TAC.
But I mean the point of a site survey is to see what kind of performance you get in a real environment, right ? And that's exactly what I wanted to see, but without being able to use 80 MHz channels, you can't test the full AP capability ...
Not really.... things get
Not really.... things get released because partners need to have them for testing.  100% functionality and what partners need is what the difference is.  Product gets announced and has to be sold, but if you look at products that have come out, you don't really get all 100% functionality right a way.  So, when we look at using a 3700 for site survey, we don't look at having to use 80mhz and connecting clients, we are looking at RF coverage patterns.  Everyone has heard, if you want to connect to AC, then you better be close to the AP.  SO in schools with an AP in every room, its understood, that many will get AC, but we are not testing throughput at all.  When the 3700's are implemented, we have a WLC and that is really what is required for testing AC.  If an when Cisco officially supports the 3700 in IOS, then it can be used in production, but you will have to wait to see when the code is released, what it will have and what it will not support.
Scotty
-Scott
Thank you Rasika.  Do you think I should just bite the bullet and purchase a 2504 Wireless Controller, or just wait out the beta process?
VIP Purple
If you could afford, yes go for a 2504 with 7.6.x code on it.  Other choice is vWLC, but you will limited on certain features & only FlexConnect mode AP can be supported.
Rasika
I have the same issue? How
I have the same issue? How can I make sure that the 2504 wireless controller has the 7.6.x code on it? Plus, are the 3702i APs and the 2504 wireless controller compatible with Cisco Catalyst 3560 PoE switches? Thanks
If you purchase a new WLC,
If you purchase a new WLC, you can request the code on the part number.  You will also have the ability to contact TAC for a firmware up to 90 days of purchase.
Scotty
-Scott
4424
