04-12-2010 07:45 AM - edited 07-03-2021 06:42 PM
I know this will sound rather simple to most, but
I can not tell if these are going to be compatible with my 2125 controllers.
I believe they are light weight access points but do not see that mentioned in
the docs I can find.
are they compatible with my 2125 controller?
thank you
04-12-2010 07:50 AM
Hi there,
Yes, the AIR-LAP1131AG-A-K9 is fully supported on the WLC 2125
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
04-12-2010 08:06 AM
thank you, that makes life easy!
