Cisco AP dual SSID in different Vlans using Cat 3750G as dhcp server
Hi All,
i had a problem configuring my AP with 2 different SSID on both vlan 2 and 3 respectively, the port are trunked with vlan 4 as native, the AP is connected to a Cat3750G acting as the DHCP server with 2 different pool of ip range 192.168.2.0/24 and 192.168.3.0/24 assigned to vlan 2 and vlan 3 respectively.
I had no problem obtaining the dhcp for vlan 2 and 3 directly when plugin to the switch but both the ssid wont give the dhcp ip allocation correctly instead its giving 169.X.X.X ips. The requirement are when im connecting to SSID2 on the AP im supposed to obtain 192.168.2.0/24 ip ranges and on SSID3 im supposed to obtain 192.168.3.0/24 ip ranges. but why am i getting 169.x.x.x.......  can somebody help me.. thanks, im able to ping to all the vlans from the AP.
the Switch config as below
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname C3750G-DHCPCore
enable secret 5 $1$z520$VyzdV1AsDthxhIfXl3f8b0
no aaa new-model
switch 1 provision ws-c3750g-48ts
system mtu routing 1500
ip subnet-zero
ip routing
ip dhcp excluded-address 192.168.2.0 192.168.2.100
ip dhcp excluded-address 192.168.3.0 192.168.3.100
ip dhcp pool vlan2
import all
network 192.168.2.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.2.1
ip dhcp pool vlan3
import all
network 192.168.3.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.3.1
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport trunk native vlan 4
switchport trunk allowed vlan 1-4
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/48
switchport access vlan 2
switchport mode access
interface Vlan1
shutdown
interface Vlan2
description Wifi_dhcp_test
ip address 192.168.2.254 255.255.255.0
ip helper-address 192.168.2.1
interface Vlan3
description Wifi_dhcp_test2
ip address 192.168.3.254 255.255.255.0
ip helper-address 192.168.3.1
interface Vlan4
description native vlan for wireless
ip address 192.168.4.254 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
The AP config as below.
version 12.4
no service pad
service password-encryption
hostname AP-WhizzTestDHCP
enable secret 5 $1$YjDw$CbhYVcc.9TQkhM0RgVJPF.
no aaa new-model
ip dhcp relay information trust-all
dot11 ssid Whizztest
vlan 2
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 045802150C2E1D1C5A
dot11 ssid Whizztest_2
vlan 3
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 110A1016141D5A5E57
power inline negotiation prestandard source
username cisco privilege 15 password 7 13061E010803
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm tkip
encryption vlan 3 mode ciphers aes-ccm tkip
ssid Whizztest
ssid Whizztest_2
mbssid
station-role root access-point
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface GigabitEthernet0.3
no ip route-cache
bridge-group 3
interface GigabitEthernet0.4
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.4.253 255.255.255.0
no ip route-cache
ip default-gateway 192.168.4.254
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz...config/help/eag
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
password 7 14141B180F0B
login local
end
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco AP dual SSID in different Vlans using Cat 3750G as dhc
Couple other changes. For vlan 2 only use TKIP since your using WPA v1. For vlan 3 use AES since your using WPA v2.
encryption vlan 2 mode ciphers tkip
-Scott
Do a show vlan , and make sure that vlan 2 and 3 are created at L2
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
VIP Purple
Hi Kian
I believe your switch acting as L3 gateway for these user vlans, If so where is 192.168.x.1 defined & what is the purpose of forwarding DHCP request to that IP. Your DHCP server is your switch itself & no helper addresses required.
Also in the DHCP pool configuration make sure you set the correct gateway for the end users. If this L3 switch SVI become gateway then default router should be 192.168.x.254.
interface Vlan2
interface Vlan3
Rasika
**** Pls rate all useful responses ****
Rasikana, i have changed the default router address to 192.168.X.254, i supposed you were refering to that? the ip helper address were supposed to point to the default router address of which pool i want to use for my DHCP IP range scope. without the IP helper set in the vlans, i will not be able to get DHCP ip assigned. right now the port 48 is configured with vlan 2 access port and port 47 is configured with vlan 3 access, and directly plugin to the switch gets me correct DHCP IP range assigned both at 192.168.2.0/24 and 192.168.3.0/24, i did changes as these
ip dhcp pool vlan2
   import all
   dns-server 8.8.8.8
   default-router 192.168.2.254
ip dhcp pool vlan3
   import all
   dns-server 8.8.8.8
   default-router 192.168.3.254
interface Vlan2
ip helper-address 192.168.2.254
interface Vlan3
ip helper-address 192.168.3.254
Hi Stephen, i have checked the vlans on both the Switch and AP, both vlans was already created.
anyone can help??? clueless after trying 2 weeks
-Scott
thanks Scott, manage to get this working already,,, didnt know encyrption combination with vlan plays an important part for DHCP IP allocation thou..... haha, and needed to configure "no bridge-group (no) block-unknown-source" on each subinterface....
dot11 ssid Whizztest_1
   vlan 1
   authentication open
   mbssid guest-mode
   vlan 2
   authentication open
   mbssid guest-mode
dot11 ssid Whizztest_3
   vlan 3
   authentication open
   mbssid guest-mode
username Cisco privilege 15 password 7 13061E010803
bridge irb
no ip address
no ip route-cache
encryption vlan 1 key 1 size 40bit 7 130F8A565122 transmit-key
encryption vlan 1 mode wep mandatory
ssid Whizztest_1
ssid Whizztest_2
ssid Whizztest_3
mbssid
Encryption combination affects many Apple Devices and some windows. This means that the client device may never authenticate properly and thus fail authentication and never get an IP address. Or they might obtain an IP address but will loose connectivity later. The IEEE standard for WPA v1 is TKIP only and WPA v2 is to use AES. So manufactures try to follow that standard and when you mix and match, it causes stability issues. Apple Devices doesn't allow you to choose TKIP or AES like windows.
-Scott
337
