Cisco AP1252AG-A-K9 V03 will not power up
Hi everyone,
I just received this unit from *ugh! eBay noob*, I paid $140 for that access point for gaming room but there's problem that I tried to power up from Power Supply, it did not power up and also tried POE Injector and POE Switch, neither of them did not power them up but PWRINJ4 said Faulty (red blinking). I'm trying to figuring it out how to solve the problem. I don't have console but do have at college. I go RIT (Rochester Institute of Tech).
These power supply I tried:
- AIR-PWRINJ4
- Power Supply with 48v to 56v
- Cisco Catalyst Express 500 with all POE
Any idea what wrong with this unit?
Why it will not power up (the LED was not lit light)?
Does it mean the hardware faulty?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
As what Steve said, the WAP is dead.
That sounds like a hardware issue to me.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: Cisco AP1252AG-A-K9 V03 will not power up
Probably but will test without radio to see if it come up.
What hardware issue that will not power up? I guess I'll look for Cisco Repair with cheaper price.
That won't work unless you removed both radio modules.  Make sure you have spare patch cables because if your patch cable is faulty you may have issues.
Where did you get this PS?  1250 power pack have an output value of 56v and 0.8A.
Can you console into the WAP?  The LED could be flashing green because the WAP is complaining that it's not getting enough power.  If this is the case, remove the two radio modules and try powering it up.  Just to test.
                    Tested with LAP1242AG with switch, it came up and running. AP1252AG without radio modules, still not lit up.
                Cisco Power Supply from LAP1242AG. I read the 1252AG manual, it said Input power requirement is range from 36v to 57v.
               Nothing of them lit up. Must be faulty inside. But is there any tip to try?
Your right. I'm gonna find the Cisco Repair. Thank you very much.
1059
