cisco autonomous 1242 bridge two switches
We are trying to configure two Cisco autonomous to work in bridge mode to connect two switches with a trunk.
the configuration:
First AP:
version 12.4
no service pad
service password-encryption
hostname Solel_10_AP
logging rate-limit console 9
enable secret 5 $1$4UyT$sd08naXSEAWXrAojCKs0f1
no aaa new-model
dot11 syslog
dot11 ssid ts25
   vlan 999
   authentication open
   authentication key-management wpa
   infrastructure-ssid
   wpa-psk ascii 7 0803604F2B3504351E2A
username Cisco password 7 096F471A1A0A
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 999 mode ciphers tkip
ssid ts25
station-role root bridge
world-mode dot11d country-code IL outdoor
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 1
interface Dot11Radio0.101
encapsulation dot1Q 101
no ip route-cache
bridge-group 101
interface Dot11Radio0.104
encapsulation dot1Q 104
no ip route-cache
bridge-group 104
interface Dot11Radio0.108
encapsulation dot1Q 108
no ip route-cache
bridge-group 108
interface Dot11Radio0.109
encapsulation dot1Q 109
no ip route-cache
bridge-group 109
interface Dot11Radio0.113
encapsulation dot1Q 113
no ip route-cache
bridge-group 113
interface Dot11Radio0.999
encapsulation dot1Q 999 native
no ip route-cache
bridge-group 255
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.10
no ip route-cache
bridge-group 1
interface FastEthernet0.101
no ip route-cache
bridge-group 101
interface FastEthernet0.104
no ip route-cache
bridge-group 104
interface FastEthernet0.108
no ip route-cache
bridge-group 108
interface FastEthernet0.109
no ip route-cache
bridge-group 109
interface FastEthernet0.113
no ip route-cache
bridge-group 113
interface FastEthernet0.999
no ip route-cache
bridge-group 255
interface BVI1
ip address 10.254.24.10 255.255.255.0
no ip route-cache
ip default-gateway 10.254.24.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
logging synchronous
login local
end
second AP:
Current configuration : 2654 bytes
version 12.4
no service pad
hostname Handasa
enable secret 5 $1$GDHp$n9MR5.72QzhxdV59PFp0/1
no aaa new-model
dot11 syslog
dot11 ssid ts25
   vlan 999
   authentication open
   infrastructure-ssid
username Cisco password 7 032752180500
bridge irb
no ip address
no ip route-cache
ssid ts25
station-role non-root bridge
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 101
no ip route-cache
bridge-group 104
no ip route-cache
bridge-group 108
no ip route-cache
bridge-group 109
no ip route-cache
bridge-group 113
no ip route-cache
bridge-group 255
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 101
no ip route-cache
bridge-group 104
no ip route-cache
bridge-group 108
no ip route-cache
bridge-group 109
no ip route-cache
bridge-group 113
no ip route-cache
bridge-group 255
interface BVI1
ip address 10.254.24.9 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
The client assocation table:
Handasa#show dot11 associations
802.11 Client Stations on Dot11Radio0:
SSID [ts25] :
MAC Address    IP address      Device        Name            Parent         State
0024.989a.ff10 10.254.24.10    11g-bridge    Solel_10_AP     -              Assoc
When we connect a computer to the switch in vlan 10 we manage to ping the local AP.
The APs can't ping each other, and there is no network connectivity between the APs.
Is there any debug/show command that can help me trobuleshoot the issue?
Best regards,
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: cisco autonomous 1242 bridge two switches
On autonomous ap, the ap has to be the native vlan. There is no way around this.
-Scott
Here is a good guide regarding configuration. I guess the question also is if the bridge can form a link first between each other. That is the first thing that needs to be done before testing the other vlans.
https://supportforums.cisco.com/docs/DOC-16087
-Scott
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 255
Bridge group number must be same as sub-interface. So, the above two are not correct.
(I advise to use subinterface, VLAN tag and bridge group numbers all the same).
Amjad
Rating useful replies is more useful than saying "Thank you"
I believe that you can make them different due to the max bridge-group number you can use and the high vlan id's that some define. You just need to make sure bridge-group 1 is defined for your native vlan.
-Scott
Yes. Scott. I remember that two of them must match, so after I refer to the doc I found that the VLAN and the Sub-Interface numbers need to match (except native vlan):
'''snip'''
Native VLAN is always mapped to Bridge Group 1 by default. For other VLANs, Bridge Group
number matches VLAN number; for example, for VLAN 46, Bridge Group is 46.
'''snip'''
This is from the mesh 7.0 guide.
I never had the time to test in practice and I am not sure if the "by default" above includes other VLANs other than the native one (which makes the meaning that this is the default only but can be changed).
soon I'll be testing all those options. If I have the time, hopefully.
Thanks Scott.
Amjad
The bridge ids aren't a requirement to match .. I have bridges that don't .. Native yes .. Vlan/trunk and interface yes ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Hi Scott,
Thank you for the answer.
When we configure the bridge-group 1 in other vlan that isn't the NATIVE it's works but only until the next reboot.
The problem is that we want the management IP to be in a diffrent vlan then the NATIVE vlan.
Do you know of a way to configure it?
Thanks alot,
Omer Shtivi
-Scott
Hello to all,
We removed the configuration of the bridge-group 1 from dot11radio0.10 and fa0.10 and we reconfigure it again and it's start working again (maybe some kind of bug? we are not sure).
Thanks everyone for all the help
Omer Shtivi
414
