Cisco C866VAE-W-E-K9 and AP
Karel Svarc
I have this model C866VAE-W-E-K9 see detail [1.], [2.].
I found a very nice article on setting up multi SSID AP see this link [3.]. However, when I connect the AP built in my router [5.] I can not use basic commands like "show ver", "show log" and so on. Is this normal for this model? I thought that this is a standard AP, which is connected by gigabit Ethernet "Wlan-GigabitEthernet0" and rest of all is similar like Aironets AP (1600). Can I uprade IOS AP? Unfortunately there is no command  like "archive dovnload-sw". So, I can not use "no" command to clear default settings and the question is how can I erase default configuration of AP? Everything what can I do on AP see [4.]
Thank you for your response and help.
Karel
[1.]
yourname#show ver
Cisco IOS Software, C860 Software (C860VAEW-ADVSECURITYK9-M), Version 15.3(3)M, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 22-Jul-13 04:37 by prod_rel_team
ROM: System Bootstrap, Version 15.3(3r)M, RELEASE SOFTWARE (fc1)
yourname uptime is 4 minutes
System image file is "flash:c860vaew-advsecurityk9-mz.SPA.153-3.M.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C866VAE-W-E-K9 (revision 1.0) with 385024K/32768K bytes of memory.
Processor board ID GMK1730009R
1 DSL controller
1 Ethernet interface
3 FastEthernet interfaces
4 Gigabit Ethernet interfaces
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
1540080K bytes of USB Flash usbflash0 (Read/Write)
131072K bytes system flash allocated
[2.]
yourname# show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  administratively down down
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
GigabitEthernet0           unassigned      YES unset  down                  down
GigabitEthernet1           unassigned      YES unset  down                  down
GigabitEthernet2           unassigned      YES NVRAM  administratively down down
Vlan1                      10.10.10.1      YES NVRAM  up                    up
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
[3.]
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/825-cisco880w-multiple-ssid.html
[4.]
ap#show ?
        ap-config                 Configuration details
        controllers               Interface controller status
        dot11                     IEEE 802.11 show information
        interfaces                Interface status and configuration
        ip                        IP information
        memory                    Memory statistics
        processes                 Active process statistics
ap(config)#no ?
% Unrecognized command
ap(config)#?
        do                        To run exec commands in config mode
        dot11                     IEEE 802.11 config commands
        end                       Exit from config mode
        exit                      Exit from config mode
        global-max-clients        Global Max Clients
        interface                 Select an interface to configure
[5.]
https://learningnetwork.cisco.com/thread/69059
(config)#interface loopback 0
(config-if)#ip address 1.1.1.1 255.255.255.255
#telnet 1.1.1.1 2002
default username/password is admin/admin but will prompt to change password. then use: ctr-shift-6...then x...then enter 'disconnect' to get out of AP.
    Salma Sulthana
    Hi Karel,
    I really appreciate your patience in posting the query. Yes, there is a command to delete the configuration using "no" followed by the configuration line.
    However, most of the commands with 'no' will not be completed automatically and you may end up in typing the complete command to delete them.
    here is the deployment and configuration guide for your 860 integrated router.
    https://supportforums.cisco.com/sites/default/files/attachments/discussion/scg880-860.pdf
    If you go through the documentation for wireless configuration, you can see commands like with "no" to delete the configuration.
    Salma
