Community Member
Cisco CAP 3702I not registered with WLC 5508.
I Have  WLC 5508 in my network. Now i need to add another 2 no of cisco CAP 3702I in to my network. But we got the following errors
*Mar  1 01:27:06.359: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC'runn
ing version 7.3.101.0 is rejected.
*Mar  1 01:27:06.359: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 01:27:06.359: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
essage type 2 state 2.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 01:27:25.359: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER
*Mar  1 01:27:25.363: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'WLC'runn
*Mar  1 01:27:25.363: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 01:27:25.363: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
*Mar  1 01:27:25.363: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Mar  1 01:27:25.363: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
acket from 10.56.200.201
LER
e from controller
Your WLC seems to be running
Your WLC seems to be running version 7.3 which is not supported with 37xx AP platform.
You need to run WLC with version 7.6.100.0 onwards to support these new AP's.
For more details check the Wireless Software Compatibility Matrix.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hall of Fame Super Silver
Your better off running v7.6
Your better off running v7.6.120.0 also and make sure you have updated the FUS to v1.9.0.0
Scott
-Scott
VIP Purple
Hi,*Mar  1 01:27:25.363:
3702I minimum required software is 7.6.100.0 so u must upgrade the wlc software.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
492
