Cisco compliant wifi bridges
Hi!
Can anybody comment on Cisco supported wifi bridges? Ie I have a device that doesn't have wireless card and needs to get on wireless network using its built in LAN card and a media bridge of some sort.
Thank you.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
There are many Ethernet converters that you can purchase, but they are not all 100% stable.  I have two different Buffalo Ethernet converters that work okay, but at times, I need to power cycle them.  Using an autonomous AP might be your best bet if this bridge needs to connect to a lightweight access point.  I also have used one of these in the past and works fine... its portable:
http://goo.gl/NDqBtQ
http://goo.gl/3261
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
http://goo.gl/3261
Scott
-Scott
Thank you Scott.
No problem...
Scott
-Scott
150
