Cisco hwic-ap with Netflix
Hey all,
I currently have a hwic-ap in my 2811 and I cannot get any droid phones to use Netflix.  I have researched and researched and found nothing as to what could be causing this and I wanted to open up a discussion.  ANY suggestions are welcome! Here is my config:
hostname 2811-CME
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.151-4.M5.bin
boot system flash c2800nm-adventerprisek9_ivs_li-mz.151-3.T.bin
boot-end-marker
security authentication failure rate 3 log
logging buffered 4096
enable secret 5 $1$wYWY$32bxwvvyIBK9tvvF2mdSg0
aaa new-model
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring last Sun Mar 2:00 last Sun Oct 2:00
no dot11 igmp snooping-helper
dot11 syslog
dot11 ssid <>
vlan 30
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 06121D204F4558405D4F
ip source-route
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.99
ip dhcp excluded-address 192.168.2.33 192.168.2.255
ip dhcp excluded-address 192.168.2.20 192.168.2.255
ip dhcp excluded-address 192.168.3.131 192.168.3.254
ip dhcp excluded-address 192.168.4.1
ip dhcp pool LAN-<>
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   option 150 ip 192.168.3.25
   domain-name <>
   dns-server 8.8.8.8 4.2.2.1
   lease 7
ip dhcp pool LAN-DMZ
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 4.2.2.1 4.2.2.2
   domain-name <>
ip dhcp pool WLAN-<>
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
   domain-name <>
   lease 7
ip domain name <>
ip host <> 192.168.2.200
ip name-server 8.8.8.8
ip name-server 4.2.2.1
no ip igmp snooping
no ipv6 cef
vpdn enable
vpdn-group 1
voice-card 0
license udi pid CISCO2811 sn FTX1115A1GG
username <>privilege 15 secret 5 $1$Pc/.$y6kJb0xpe.77ciRHZTJ8A.
username <> password 7 14141B180F0B7B7977
redundancy
ip ssh version 2
bridge irb
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
description ### UPLINK TO INET (USES DIALER1) ###
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1
description ### TO 3750 ###
no ip address
ip nat inside
ip virtual-reassembly in
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/1.20
description ### DMZ ###
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1.30
description ### <>VLAN ###
encapsulation dot1Q 30
ip helper-address 192.168.3.1
ip nat inside
no ip route-cache
bridge-group 1
interface FastEthernet0/1.200
description ### SERVER VLAN ###
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip nat inside
no ip route-cache
interface Serial0/0/0
description ### TO LAB ###
ip address 192.168.50.1 255.255.255.252
ip nat inside
clock rate 8000000
interface Dot11Radio0/2/0
no ip address
ip nat inside
no ip virtual-reassembly in
encryption vlan 30 mode ciphers aes-ccm
ssid <>
speed basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2412
station-role root access-point
interface Dot11Radio0/2/0.40
description ### SSID <>###
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Service-Engine1/0
ip unnumbered FastEthernet0/1.30
interface Virtual-Template1
ip unnumbered BVI1
interface Virtual-Template7
ip unnumbered Dialer1
interface Dialer1
description ### VIRT INT TO INET ###
ip address negotiated
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <>
ppp chap password 7 101E5C4B5C4F4A1B0D0920
ppp timeout idle 180
interface BVI1
ip address 192.168.3.1 255.255.255.0
ip nat inside
router eigrp 1
network 1.0.0.0
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
router ospf 1
router-id 0.0.0.1
network 192.168.50.0 0.0.0.255 area 0
ip local pool SSL-VPN 192.168.11.5 192.168.11.8
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/cme/GUI
ip nat inside source list 2 interface Dialer1 overload
ip nat inside source static tcp 192.168.3.1 22 interface Dialer1 22
ip nat inside source static tcp 192.168.3.210 25565 interface Dialer1 25565
ip nat inside source static tcp 192.168.2.200 80 interface Dialer1 80
ip route 0.0.0.0 0.0.0.0 Dialer1
logging esm config
logging 192.168.3.201
access-list 2 remark ***NAT***
access-list 2 permit 192.168.2.0 0.0.0.255
access-list 2 permit 192.168.3.0 0.0.0.255
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 192.168.125.0 0.0.0.255
access-list 2 permit 192.168.6.0 0.0.0.255
access-list 2000 permit ip host 192.168.3.1 host 192.168.3.200
dialer-list 1 protocol ip permit
nls resp-timeout 1
cpd cr-id 1
225
