Cisco Indoor/Outdoor Antennas
Hi All,
Kindly excuse my ignorance. Please explain to me or point me to documentations that explain the effect of using an indoor antenna such as Ceiling mount omni-directional in an outdoor environment. Are there environmental implications such as rain?
Thanks.
Chafe
Re: Cisco Indoor/Outdoor Antennas
I have some urls on this , may help you
Antennas - General
Antennas ship with basic hardware to mount antennas (such as U-bolts), but not the mast itself.
Basic mounting hardware is included with all antennas (except patch, whi
ch mount directly to wall).
Keep bridge antenna cables as short as possible (significant effect on r
ange/transmission rate).
If possible, use fiber and transceivers to connect Bridge to LAN (lightning doesnot travel over fiber).
Cables are not plenum-rated.
Use the calculator tool for bridge antennas/cables.
Antenna needs to be polarized in the same manner for proper operations ,
There are
Two planes of RF , E plane and H plane and they are 90 degree from each other .
Horizontal polarization is best for transmissions over water, since vert
ical polarizations exhibit a 180 degree phase shift and result in multipath pro
blems at the far end of the circuit.
Data sheet for Antenna :
http://www.cisco.com/warp/public/cc/pd/witc/ao340ap/prodlit/airoa_ds.htm
Antenna Reference Guide :
http://www.cisco.com/warp/public/cc/pd/witc/ao350ap/prodlit/agder_rg.htm
Antenna Basic :
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350brdgs/brhig/br350apc.htm
Mounting Instruction :
http://www.cisco.com/univercd/cc/td/doc/product/wireless/aironet/miscell/index.
htm
Diagnostics And Troubleshooting :
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350brdgs/brscg/br350ch8.htm
335
