For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
cisco LAP 3502i -A issue
There is a cisco  3502I- A  AP in shanghai office ,  the WLC is 4402 in Singapore , last few days , the shanghai office say they can't see the ssid , I  check the WLC , it's seems the 3502I's admin status is disable ,  so I enable it manual . It works 2 days ,then the same issue is appeard . Anybody can help me ? The AP's log :
*Nov  7 19:44:06.928:  status of voice_diag_test from WLC is false
*Nov  7 19:44:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.65.80.43 peer_port: 5246
*Nov  7 19:44:06.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov  7 19:44:06.754: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.65.80.43 peer_port: 5246
*Nov  7 19:44:06.754: %CAPWAP-5-SENDJOIN: sending Join Request to 10.65.80.43
*Nov  7 19:44:06.754: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov  7 19:44:11.756: %CAPWAP-5-SENDJOIN: sending Join Request to 10.65.80.43
*Nov  7 19:44:12.014: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov  7 19:44:13.486: %CAPWAP-5-CHANGED: CAPWAP changed state to DOWN
*Nov  7 19:44:13.754: %LWAPP-3-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Nov  7 19:44:13.946: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller SG-SG-NT-WLC1
*Nov  7 19:44:14.037: %LWAPP-3-CLIENTEVENTLOG: SSID SH added to the slot[0]
*Nov  7 19:44:15.176: %LWAPP-3-CLIENTEVENTLOG: SSID SHGUEST added to the slot[0]
*Nov  7 19:44:15.270: %LWAPP-3-CLIENTEVENTLOG: SSID SHWIRELESS added to the slot[0]
*Nov  7 19:44:15.427: %LWAPP-3-CLIENTEVENTLOG: SSID SH added to the slot[1]
*Nov  7 19:44:15.559: %LWAPP-3-CLIENTEVENTLOG: SSID SHGUEST added to the slot[1]
*Nov  7 19:44:15.663: %LWAPP-3-CLIENTEVENTLOG: SSID SHWIRELESS added to the slot[1]
*Nov  7 19:44:16.604: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Nov  8 00:40:35.952: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.65.80.43:5246
*Nov  8 00:40:36.008: %WIDS-5-DISABLED: IDS Signature is removed and disabled.
*Nov  8 00:40:36.008: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov  8 00:40:36.084:  status of voice_diag_test from WLC is false
*Nov  8 00:41:26.085: %LWAPP-3-CLIENTEVENTLOG: Switching to Standalone mode
*Nov  8 00:42:34.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.65.80.43 peer_port: 5246
*Nov  8 00:42:34.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov  8 00:42:34.883: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.65.80.43 peer_port: 5246
*Nov  8 00:42:34.883: %CAPWAP-5-SENDJOIN: sending Join Request to 10.65.80.43
*Nov  8 00:42:34.883: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov  8 00:42:39.885: %CAPWAP-5-SENDJOIN: sending Join Request to 10.65.80.43
*Nov  8 00:42:40.171: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov  8 00:42:41.659: %CAPWAP-5-CHANGED: CAPWAP changed state to DOWN
*Nov  8 00:42:41.930: %LWAPP-3-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Nov  8 00:42:42.119: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller SG-SG-NT-WLC1
*Nov  8 00:42:42.172: %LWAPP-3-CLIENTEVENTLOG: Switching to Connected mode
*Nov  8 00:42:42.248: %LWAPP-3-CLIENTEVENTLOG: SSID SH added to the slot[0]
*Nov  8 00:42:43.393: %LWAPP-3-CLIENTEVENTLOG: SSID SHGUEST added to the slot[0]
*Nov  8 00:42:43.531: %LWAPP-3-CLIENTEVENTLOG: SSID SHWIRELESS added to the slot[0]
*Nov  8 00:42:43.685: %LWAPP-3-CLIENTEVENTLOG: SSID SH added to the slot[1]
*Nov  8 00:42:43.824: %LWAPP-3-CLIENTEVENTLOG: SSID SHGUEST added to the slot[1]
*Nov  8 00:42:43.953: %LWAPP-3-CLIENTEVENTLOG: SSID SHWIRELESS added to the slot[1]
*Nov  8 00:42:45.217: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Nov  8 00:46:38.630: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.65.80.43:5246
*Nov  8 00:46:38.687: %WIDS-5-DISABLED: IDS Signature is removed and disabled.
*Nov  8 00:46:38.687: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov  8 00:46:38.759:  status of voice_diag_test from WLC is false
*Nov  8 00:46:47.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.65.80.44 peer_port: 5246
*Nov  8 00:46:47.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov  8 00:46:47.767: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.65.80.44 peer_port: 5246
*Nov  8 00:46:47.767: %CAPWAP-5-SENDJOIN: sending Join Request to 10.65.80.44
*Nov  8 00:46:47.767: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov  8 00:46:52.769: %CAPWAP-5-SENDJOIN: sending Join Request to 10.65.80.44
*Nov  8 00:46:53.061: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov  8 00:46:54.530: %CAPWAP-5-CHANGED: CAPWAP changed state to DOWN
*Nov  8 00:46:54.798: %LWAPP-3-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Nov  8 00:46:54.983: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller SG-SG-NT-WLC2
*Nov  8 00:46:55.081: %LWAPP-3-CLIENTEVENTLOG: SSID SH added to the slot[0]
*Nov  8 00:46:56.229: %LWAPP-3-CLIENTEVENTLOG: SSID SH added to the slot[1]
*Nov  8 00:46:57.198: %WIDS-5-ENABLED: IDS Signature is loaded and enabled
*Nov  8 00:51:31.037: %LWAPP-3-CLIENTEVENTLOG: SSID SHGUEST added to the slot[0]
*Nov  8 00:51:31.037: %LWAPP-3-CLIENTEVENTLOG: SSID SHGUEST added to the slot[1]
*Nov  8 00:51:43.274: %LWAPP-3-CLIENTEVENTLOG: SSID SHWIRELESS added to the slot[0]
*Nov  8 00:51:43.292: %LWAPP-3-CLIENTEVENTLOG: SSID SHWIRELESS added to the slot[1]
*Nov  8 01:57:08.157: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Nov  8 01:57:08.321: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 01:57:08.337: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 01:57:09.356: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov  8 01:57:18.368: %CLEANAIR-5-STATE: Slot 0 disabled
*Nov  8 02:03:09.795: %LWAPP-5-RLDP: RLDP started on slot 0.
*Nov  8 02:03:09.798: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:09.814: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:09.827: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:09.833: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:09.846: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:09.861: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:31.199: %LWAPP-5-RLDP: RLDP stopped on slot 0.
*Nov  8 02:03:31.202: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:31.218: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:31.233: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:31.240: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:31.252: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:31.268: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:31.435: %LWAPP-5-RLDP: RLDP started on slot 0.
*Nov  8 02:03:31.438: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:31.451: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:31.466: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:52.624: %LWAPP-5-RLDP: RLDP stopped on slot 0.
*Nov  8 02:03:52.628: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:52.643: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:52.659: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:52.665: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Nov  8 02:03:52.678: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  8 02:03:52.694: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  8 02:03:52.879: %LWAPP-5-RLDP: RLDP started on slot 0.*Nov  7 19:44:06.928:  status of voice_diag_test from WLC is false
The RLDP is still start-down-start-down , how to slove it ?
  • Getting Started with Wireless
Hello Yafeng,
Access Points going Admin Disabled are typically due to Country code regulatory configurations on your WLCs. From your logs, it looks like this AP is moving between :
SG-SG-NT-WLC1
SG-SG-NT-WLC2
Is there a chance that you have different country settings on these WLCs? How about different AP-group configurations?
RLDP is not going to cause admin disabled state -- RLDP simply takes the radio offline for a very short time to associate to Rogue APs -- you can disable this feature to stop these radio resets.
-Pat
Thanks for your help, I have already disable RLDP on this AP,WLC1 and WLC2 have the same configurations now 。
Also taking a look at
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a_ps6087_Products_Data_Sheet.html
Singapore is -S and China -C, you shouln't be using a -A AP in these regulatory domains.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thanks for your help . This ap is 3502I -A ,during the Initial setup ,the Singapore' IT found he can't set AP's country code to china after he add china to WLC's country setting ,so he set both WLC and AP to Australian,then this issue began to appear.  He ask me to help,  I found  -A for 3502I 's country code must be US or Canada from cisco‘s document,so I set the WLC and this AP ’s country code both are US now,but this issue is also have . Do you have any proposal ?
BR
yafeng
1150
