Cisco voice issues with 7.4.121.0 code with 3502i and 3602i (but not Cisco 1130 series)
We have a WiSM2 with 500 access points on it.  The voice WLAN ran fine with our 7925 series, until our upgrade to this code AND swapping out the 1130s for 3502 series.
We can take phones over to one of our other buildings that is on this controller that is running the 1130s still and the voice works as it should.  When we take the phones to the building with the 3502s, the voice gets choppy, etc.  The voice WLAN is 5GHz.
The only difference is the APs, the AP Group mapping to different L3 subnet, and the physical location of the building, which is 1000 feet away.  These buildings are quite large - hundreds of access points.
802.11n is not enabled.  We would assume that voice would be better on the 3502s and worse on the 1130s, however we are seeing the exact opposite.
I'm wondering if there's something we need to turn off/on on the WLC because of the difference in APs.
VIP Purple
Pls attached "show wlan <wlan
Pls attached "show wlan <wlan_id>" output to see.
Did you check the power level of these 3502s  in 5GHz band ?  Are they operating high power (level 1) or low power level (3-5).
Also did you notice any roaming issues with 3502s compare to 1131
Rasika
**** Pls rate all useful responses ****
 WLAN Identifier.............
WLAN Identifier.................................. 5
Profile Name..................................... SHVoice2
Network Name (SSID).............................. SHVoice2
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 170
Exclusionlist.................................... Disabled
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... sac001-001-wc09
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ vlan128
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Platinum
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... ap-cac-limit
Wired Protocol................................... 802.1P (Tag=6)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11a only
DTIM period for 802.11a radio.................... 2
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 10.153.13.63 1812
   Authentication................................ 10.169.3.46 1812
   Authentication................................ 10.153.1.40 1812
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
--More-- or (q)uit
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Enabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
--More-- or (q)uit
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
--More-- or (q)uit
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
VIP Purple
HiCan you disable this & see
Can you disable this & see (assume you do not have 7920s in your environment)
Rasika
I am not sure if there are
I am not sure if there are any 7920 phones.  I noticed that the bug that allows a WLAN Profile to bcast in both frequencies is there.  The wlan profile states 5GHz only.  It is bcasting in both freqencies.  Phones need to be set to 5GHz now.
Hall of Fame Super Gold
Value of "6"?  This is wrong.  This should be "5".  This is particularly true when you are using anything newer than 7.4.100.X.
And what firmware is the phone running on?
Leo, where did you find that
Leo, where did you find that documented?  I want to research that!  Thanks!
The old (as in VERY, VERY,
The old (as in VERY, VERY, VERY old) Cisco documentation about wireless "best practice" has specified the 802.1P tag to be set as "6".  This, as it turns out to be, was a mistake or a "bug".
So if you have this turned to "6" and you upgraded the firmware of your WLC, this will automatically change to "5".
Here's the power/channel...
A couple ideas:Is your DHCP
A couple ideas:
Is your DHCP pool on a windows box, and if so, is the VOIP DHCP pool in the super scope?  I have run into issues, specifically with cisco phones if the DHCP pool is in the super score, especially when roaming.
I would capture a debug of a phone roaming on the 1131's and then on the 3502's and compare.
I would check the phone firmwire.  I know you are running both 1131's and 3502's on 7.4.121.0, but still worth a look.
Good luck, keep us posted on your progress.
206
