Cisco WAP join problems
Greetings!
I have recently purchased a Cisco 2500 wireless access controller to run three AIR-CAP-1602E wireless access points.
I have assigned a static IP to the controller, advertised it in DNS as CISCO-CAPWAP-CONTROLLER and on DHCP option 43.
The controller is currently the only one on the network and is configured as the AP manager.
Our switches and clients are on VLAN1 (the only VLAN in use) but the controller is on VLAN0 (or untagged as I understand it).
I attempted at one point to change the controller to VLAN1 but it was then inaccessible from the management interface and I had to reset the VLAN from the console.
The access points will not join the controller and will not keep an IP address (if I monitor my DHCP servers it will pull an IP from one, then release it and pull an IP from the other, endlessly cycling).
The console messages from the AP are as follows:
Not in Bound state.
*Mar  1 02:46:07.311: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 02:46:10.319: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 02:46:10.387: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.93, mask 255.255.255.0, hostname APfc99.47a7.a2eb
*Mar  1 02:46:18.311: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 02:46:28.311: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_56:87:84'running version 7.0.220.0 is rejected.
*Mar  1 02:46:28.311: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 02:46:28.311: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 02:46:28.311: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 02:46:28.311: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 192.168.1.169
*Mar  1 02:46:28.315: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_56:87:84'running version 7.0.220.0 is rejected.
*Mar  1 02:46:28.315: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 02:46:28.315: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 02:46:28.315: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Both the AP and the controller are on the same subnet (which is incidentally our only subnet), are attached to a Cisco Catalyst 4948E switch with IP routing enabled (though it does not show in the running config for some reason) and are visible in Cisco Network Assistant.
On a whim I deleted the DHCP option and restarted the access point but it is still bouncing from DHCP server to DHCP server, never settling on an IP.
I am at a complete loss here, so any help would be appreciated.
Thank you!
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
The 1602's require v7.4.  You need to upgrade thw WLC.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott
-Scott
Great, I had a feeling it would be something as simple as "Just do this one thing and poof".
I have to coordinate with my Cisco partner to get the download authorized for my Cisco ID but will mark this answered as soon as that happens.
Thanks!
Re: Cisco WAP join problems
No problem. Keep that link handy for future use.
-Scott
Hall of Fame Super Gold
Aside from what Scott has mentioned (about your firmware needs upgrading), can you also post the output to the following commands:
1. WLC: sh sysinfo; and
2. AP: sh version
Sent from Cisco Technical Support Nintendo App
From WLC:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_56:87:84
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.169
Last Reset....................................... Power on reset
System Up Time................................... 5 days 4 hrs 31 mins 29 secs
System Timezone Location......................... (GMT -7:00) Mountain Time (US and Canada)
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
--More-- or (q)uit
Next Boot License Type........................... Permanent
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +17 C
External Temperature............................. +22 C
Fan Status....................................... 4200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 7C:69:F6:56:87:80
Maximum number of APs supported.................. 5
From AP:
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 12:40 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
APfc99.47a7.a2eb uptime is 0 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602E-A-K9    (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1733S4SA
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: FC:99:47:A7:A2:EB
Part Number                          : 73-14508-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC172165P8
Top Assembly Part Number             : 800-38553-01
Top Assembly Serial Number           : FGL1733S4SA
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602E-A-K9
Configuration register is 0xF
You can see from the log that the AP rejected the join:
Scott
-Scott
It's also a mesh image, so you will need to add the ap Ethernet MAC address in the Mac filter. Once it joins then change the mode from bridge to local.
Follow this guide
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a0080b1c101.shtml
-Scott
That did it, took a while to get the contract straightened out but my APs joined the controller just fine.
Now to configure everything...lol.
Thanks so much for the help!
237
