Cisco Wireless Controller 5508 and Aironet 3600e AP
Hello guys,
My company wants to install a new WiFi Network and we thought about purchasing a Cisco Wireless Controller 5508 together with some Aironet 3600e APs (10 APs to start with).
I once took a CCNA class and I learned basic configuration using CLI but the course didn't cover the WiFi part and It's been a long time... and since I never used it in real life I kinda forgot it.
My question is: -Does this controller have a Web Interface (GUI) for easy configurations?
                      - Can I configure the Aironet 3600e through a GUI?
                      - Let's say we decide to buy two of these controllers for redundancy, should we buy the same number of licences on the second one?
                      - What would you recommend in terms of Network Control System...etc.
                      - What else should I think about?
Thanks!
3 ACCEPTED SOLUTIONS
Bronze
Re: Cisco Wireless Controller 5508 and Aironet 3600e AP
The WLC are managed via the GUI or cli.
You just need to go through the configuration wizard and once the unit has an ip address on the management interface you can use the gui to configure the unit.
Since you will use a wlc , once the lwapp units or lwapp ap have joined the wlc using a layer 3 or layer 2 discovery method they join the wlc and you just need to access the wlc to configure the aps.
Regarding license the best thing is to have the same amount of access points so of primary wlc goes down all of your aps can move and be supported on the backup wlc .
I might shy away from WCS, as its being replaced with NCS.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Hall of Fame Super Gold
Yes.
You configure (using GUI or CLI) the WLC and the WLC will "control" the WAPs.  You DO NOT configure the WAPs.  The WLC will do that for you.
The license of the number of WAPs supported per unit.  Yes, it's recommended.
Think about Cisco Prime NCS instead of WCS.
For the 3600 to work, you need to run the 7.2.X firmware.
Read the Configuration Guides.
Bronze
Bronze
Regarding network control remmeber that the wlc will manage all the aps registered to it abd if you want to manage several wlc then you can use a wcs to manage several wlc by using one device.
Bronze
Yes you are right better to use the NCS
Yes.
Thanks a bunch to all of you who took a time to reply to my post. This is so helpful!
Bronze
NP any time.
And thank you for taking the time to rate our posts.
2138
