08-01-2012 11:45 AM - edited 07-03-2021 10:29 PM
I have a Cisco WLan 2504 controller which after a reboot has lost network connectivity, when I connect via console it is stuck on loading image, Please help as I am not knowledgeable with Cisco stuff and only bought this as it has web interface.
Hasin
Solved! Go to Solution.
08-01-2012 02:44 PM
Contact Cisco TAC and get the WLC RMA-ed.
08-01-2012 02:44 PM
08-02-2012 02:08 AM
Thanks, But the device was working fine, it still fires up seems like OS image has becomen corrupt can I not just restore it? I have the image file downloaded can I not just copy to compact flash?
Hasin
08-02-2012 06:21 AM
Hasin did you try to reboot couple of times. Is it still stuck on the same screen.
08-02-2012 04:48 PM
Device might be fine but the CF isn't.
08-05-2012 12:25 PM
below is where it stuck on, Please help.
50%
51%
52%
53%
54%
55%
56%
57%
58%
59%
60%
61%
62%
63%
64%
65%
66%
67%
68%
69%
70%
71%
72%
73%
74%
75%
76%
77%
78%
79%
80%
81%
82%
83%
84%
85%
86%
87%
88%
89%
90%
91%
92%
93%
94%
95%
96%
97%
98%
99%
100%
31535298 bytes read
Launching...
Launching images...
08-05-2012 12:38 PM
Nothing we can do to help you with this. You need to open a TAC case and they will either walk you thought the image upload or they will RMA the wlc.
