Cisco Wireless Roaming - Redundancy
I'm looking for 2 types of solution:
1. Wireless Roaming without a controller
2. Access Point redundancy - Two Access Point with the same coverage but in a Active/Standby scheme. Is this posible?
Thanks.
Ivan
1 ACCEPTED SOLUTION
Roaming is going to work so
Roaming is going to work so long as your configuration matches on the AP. i.e the PSK and SSID are the same.
If you are doing 802.1X then you would want to configure one of the AP as a WDS master so that you aren't having to authenticate all the way back to AAA on a roam.
WDS Configuration:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1100-series/44720-WDS.html
You can also configure Hot Standby on an AP: http://www.cisco.com/c/en/us/td/docs/routers/access/wireless/software/guide/RolesHotStandby.html#wp1037487
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
1 REPLY
WDS Configuration:
HTH,
Steve
33
