Cisco WLC 2500 DHCP issue
I'm having an issue with a DHCP server on one VLAN.  When clients configure a static IP they can ping the DHCP server and everything, but when they try to get the DHCP IP they do not see anything.  Customer who owns the DHCP server is saing that they are not even seeing the DHCP packets.  Here is the debug:
DHCP Socket Task: Feb 18 14:39:07.133: 00:24:d7:5f:b5:e0 DHCP selecting relay 1 - control block settings:
                        dhcpServer: 0.0.0.0, dhcpNetmask: 0.0.0.0,
                        dhcpGateway: 0.0.0.0, dhcpRelay: 10.40.0.210  VLAN: 512
*DHCP Socket Task: Feb 18 14:39:07.133: 00:24:d7:5f:b5:e0 DHCP selected relay 1 - 10.40.0.254 (local address 10.40.0.210, gateway 10.40.0.254, VLAN 512, port 13)
*DHCP Socket Task: Feb 18 14:39:07.133: 00:24:d7:5f:b5:e0 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Feb 18 14:39:07.133: 00:24:d7:5f:b5:e0 DHCP selected relay 2 - NONE
*DHCP Socket Task: Feb 18 14:39:07.133: 00:24:d7:5f:b5:e0 DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP   xid: 0xced51f7a (3470073722), secs: 6656, flags: 8000
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP   chaddr: 00:24:d7:5f:b5:e0
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP   siaddr: 0.0.0.0,  giaddr: 10.40.0.210
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP sending REQUEST to 10.40.0.254 (len 350, port 13, vlan 512)
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Feb 18 14:39:07.134: 00:24:d7:5f:b5:e0 DHCP selected relay 2 - NONE
Hall of Fame Super Silver
Re: Cisco WLC 2500 DHCP issue
Try to disable dhcp proxy and make sure you have an ip helper on the layer 3 subnet to point to the dhcp server.  You can also have your client connect a wired machine to the same switch on the vlan you are trying to test with and see if dhcp is working for the wired side on that switch.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
The only reason I mentioned to disable dhcp proxy is because maybe the customer's dhcp server doesn't like the dhcp request to be proxied.  But by default, the WLC will proxy the dhcp request.
Scott
-Scott
Thank you for the reply Scott.  I have the DHCP Proxy disabled Globally on the WLC.  Also if I connect a hardwired client to that switch and move the switch port in VLAN512 client gets an IP address.
Now this setup is a bit different.  This particular VLAN 512 is not on our network we have have it in our VLAN database on our switches.  But one of our switches uplinks to one of their switch via trunk port allowing only VLAN 512.
That is weird.... Your ap's are in local mode and you have a wlan that places traffic onto vlan 512.  The connection from the WLC and the switch is a trunk, etherchannel or access port?
Scott
-Scott
Yup we spent 2 hours on this.  It is a trunk port, here is the config on the port:
interface FastEthernet0/24
switchport trunk allowed vlan 512
switchport mode trunk
ip dhcp snooping trust
AP's are in local mode.  I do have a WLAN SSID and then assigned it to VLAN512 interface.  I can ping the DHCP server from the controller successfully.
Try removing this:
Post your show wlan
When a client tries to associaite to the SSID, can you look at the client in the monitor and post that info.
Scott
-Scott
I can remove it however on the switch DHCP snooping is enabled, but I'll test it anyways without it.  I believe it was not on that port initially.  Will let you know the results.  Here is the show wlan:
WLAN Identifier.................................. 4
Profile Name..................................... VLAN512
Network Name (SSID).............................. VLAN512
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... WLC-01
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ vlan512
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... 802.11b and 802.11g only
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
--More-- or (q)uit
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
--More-- or (q)uit
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
--More-- or (q)uit
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
For interface VLAN512, you have the switch ip for the primary DHCP server?
Scott
-Scott
Switch IP for the primary DHCP Server?  Can you elaborate I didn't understand my apologies.
Under the interface that you have defined in the WLC... VLAN512, there is a section to define your primary and secondary dchp server for that interface.  I would add your switch ip there, since that is doing your dhcp, correct?
Scott
-Scott
Ah gotcha, no for that particular VLAN it is their firewall that is also their gateway acting as a DHCP server.
Okay... so can you put the FW ip address (gateway) as the primary dhcp.
Scott
-Scott
I did though.  Here is the screen shot.
Disable DHCP proxy on the interface.
-Scott
It is Globally disabled, but I did it on the interface as well.  Bleh no one to test it with any more onsite.  So will check it tomorrow and post back results.
Sounds good. Keep us posted.
-Scott
So I tried that option as well and same results.  It seems like Controller is not advertising the DHCP server with this particular VLAN.  However with others it is and I see the following message:
DHCP   server id: 10.141.90.2  rcvd server id: 10.141.90.2
But the one that is not working
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP received op BOOTREQUEST (1) (len 308,vlan 0, port 13, encap 0xec03)
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP processing DHCP DISCOVER (1)
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP   xid: 0x3d72be50 (1030930000), secs: 1024, flags: 8000
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP   chaddr: a0:88:b4:92:45:80
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Feb 24 11:27:15.972: a0:88:b4:92:45:80 DHCP successfully bridged packet to DS
Also is DHCP Proxy enabled by default on the WLC?
By default it is enabled. You can try to disable it but you will need to make sure you have an IP helper configured.
-Scott
Yes. What Scott said is correct. First try connecting a wired client in the sameVLAN and test.
Make sure that spanning tree is forwarding that Vlan.
-Scott
Yup it is.
VLAN0512
  Spanning tree enabled protocol rstp
  Root ID    Priority    4608
             Address     0c68.0340.0e00
             Cost        4
             Port        25 (GigabitEthernet0/1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    33280  (priority 32768 sys-id-ext 512)
             Address     5017.ff99.8b80
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Fa0/24              Desg FWD 19        128.24   P2p
Gi0/1               Root FWD 4         128.25   P2p
Gi0/2               Desg FWD 4         128.26   P2p
I'm wondering if it has to do with the "disable broadcast" option.  I have created a case with TAC as well.  So curious.
Well so far TAC is unable to help either.
Since TAC has the ability to look at your configuration, they would be better in figuring out this issue to be honest.  If you disabled dhcp snooping, disable dhcp proxy and that didn't help and you can get a wired client to get an ip address, then I really don't know what else you can try.  I would just keep TAC involved.
Scott
-Scott
on the WLC CLI
show arp switch
make sure the WLC is learning ARP for the GW of VLAN 512
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Looks like it is there:
    MAC Address        IP Address     Port   VLAN   Type
CC:3E:5F:29:6A:5F   10.40.0.241      13     512    Host
CC:3E:5F:29:6A:81   10.40.0.243      13     512    Host
00:25:90:93:D8:F4   10.40.0.254      13     512    Host (This is the gateway/DHCP Server)
Thank you for the reply, yeah I'm kinda lost myself.  I think I might have to change my TAC engineer because the one I was talking to was not grasping the concept.
Haha... Maybe it's something you need to do.
-Scott
484
