Cisco WLC 5508 HA Configuration Issue
I am unable to make HA WLC as primary and secondary.
I have 2 wlc 5508 controller and making it as primary and secondary device.
one WLC as inbuilt 25 ap licence and another (Secondary) WLC have no licence
I have configure WLC in GUI as below
i have configured Mgmt port / redundant Mgmt port / Peer redundancy Mgmt port with same network address.
make one wlc as primary and another as a secondary
Connected both of wlc with RP (Redundancy Port).
Then enable SSO in both wlc,  it ask me to reboot the device and I done.
While reboting it was unable to search peer, find below detail.
Starting Licensing Services: License Request Failed :User failed to accept EULA
ok
Starting Redundancy: Starting Peer Search Timer of 120 seconds
Role Negotiation timeout. Didn't find Peer..
Imp Note :-- Earlier my 1 of wlc which am making secondary wlc was showing hostname like AIR-CT5508-HA-K9 then I found some issue in wlc so i make it as factory default and now automatically its name is  chenged to  AIR-CT5508-K9.
please help me...
VIP Purple
Re: Cisco WLC 5508 HA Configuration Issue
Do you have 2nd wlc with HA-SKU license or ????
If you dont have HA SKU license then you must have atleast 50 AP licence on 2nd WLC to convert it to Secondary.
Hi Sandeep,
I am checking licence status in 2nd WLC it showling result below.
(Cisco Controller) >show license status ?
This command is Not allowed on a HA-SKU Controller
(Cisco Controller) >show license summary
This is a Controller with HA-SKU license.
The licenses has been inherited from the Primary Controller.
Any license on HA-SKU controller is disregarded.
How to check license ?
After doing HA activity i am unable to get GUI ..
VIP Purple
Means you have the controller with HA SKU licence, its ok.
did you connected both WLC ?
as per this error:
Means you did not accept the licence:
If you are prompted to accept the end-user license agreement (EULA), read and accept the terms of the agreement.
Typically,  you are prompted to accept the EULA for evaluation, extension, and  rehost licenses. The EULA is also required for permanent licenses, but  it is accepted during license generation.
please follow this guide:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113681-high-availability-dg-00.html
Dont forget to rate helpful posts
I have made a mistake while writing note in my actual post instade of model number i have written host name.
correct is
Imp Note :-- Earlier my 1 of wlc which am making secondary wlc was showing Model no. AIR-CT5508-HA-K9
then I found some issue in wlc so i make it as factory default and now automatically its Model no.  chenged to
AIR-CT5508-K9
Hi Sandeep,
Exact i ahve follow process which is shown in link and also my both wlc are connected to each other to Redencency port
Again I am making clear that I have 2 WLC one is AIR-CT5508-K9 and second one is AIR-CT5508-HA-K9.
while config secondary wlc, due to some issue I have done my secondary  wlc is factory default after come up it is showing model no.
So I am thinking that some thing has happen and its HA-SKU license has been removed,I am sending u licence detail.
If it is not their how i can get back HA-SKU license and install.
(Cisco Controller) >show license all
License Store: Primary License Storage
StoreIndex:  0  Feature: base                              Version: 1.0
        License Type: Permanent
        License State: Active, Not in Use
        License Count: Non-Counted
        License Priority: Medium
License Store: Evaluation License Storage
StoreIndex:  0  Feature: base-ap-count                     Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  4 days
        License Count: 500 / 0 (Active/In-use)
        License Priority: None
                License Type Supported
        permanent  Non-expiring node locked license
        extension  Expiring node locked license
        evaluation Expiring non node locked license
                License Operation Supported
        install    Install license
        clear      Clear license
        annotate   Comment license
        save       Save license
        revoke     Revoke license
                Device status
        Device Credential type: DEVICE
        Device Credential Verification: PASS
        Rehost Type: DC_OR_IC
        CDK Version: 1.2.1 Build 0
VIP Purple
HI tarun,
If you facing issue with license then please raise a TAC case they will help you.
Just call them and let them know about licence rehost..or..
http://www.cisco.com/c/en/us/support/web/tsd-cisco-worldwide-contacts.html
Dontr forget to rate helpful posts
I have resolve this issue, Their is absoloutly no problam about EULA issue.
Just i did both of device in factoty default and while it is asking at starting all of information about abt mgmt ip etc ....
their I selected Enable HA mode an configured HA detail which I was asked at that level.
after reboot it becom HA device.
I mean to say if u r unable to configure HA, you can try factory default and continue at startup level and configure HA from their only.
VIP Purple
Hi Tarun,
my suggestion was depend on your ligs,,, what I can see was that EULA failure.
But it's good that you did again from scratch , that's otherway to resolve the problem.
Glad that finally you got it. Thanks for posting your resolution, it may help others.
Don't forget to rate helpful posts
1858
