Cisco wlc 5508 with 30 Vlan
Hello
i need your help
i want to configure Cisco WLC 5508 whith 03 vlans, 3750 as core swich
- management Vlan
- local-user vlan
- Guest Vlan
i want to know all steps or config to do on WLC
thx
VIP Purple
Hi,Just check this.It may
Just check this.
It may help u.
Wireless LAN Controller and Lightweight Access Point Basic Configuration Example
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/69719-wlc-lwap-config.html
http://rscciew.wordpress.com/2014/01/22/configure-dynamic-interface-on-wlc/
Webauth for guest users:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69340-web-auth-config.html
http://rscciew.wordpress.com/2014/06/19/wlc-webauth-configuration/
thank's for all answers
Hello,For the port connecting
For the port connecting switch and controller make sure its trunk  & create the three VLANs you want to use
After the initial configurations you will have management VLAN  (as its required to enter the managment IP)
Controller -> interfaces
create the two interfaces for local-user vlan and guest vlan
make sure to enter the correct vlan/ subnet/ gateway / DHCP
Now go to WLAN tab
create the SSIDs and link each to the interface
You can add different security settings for each WLAN.
Hope this was helpful!
Cheers,
Nour
53
