03-12-2014 07:34 AM - edited 07-05-2021 12:24 AM
Hi all
we are looking to deploy 2 wireless controllers, 1 in each of our offices.
We want the site AP's to fail over to the other controller should one of them go down.
My question is, the LAN ip adressing should be different on each site, so they can break out of there local internet etc.
Will this be OK ?
do we have to configure the AP's in HREAP ? So the vlans can break out on the local LAN?
also I gather we would have to have 2 AP groups one per site ?
cheers
Carl
03-12-2014 11:33 AM
Hello Carl.
You can use differente ip addressing in each site, and it works. I tested some months ago.
Yes you need to select Flex-Connect as operational mode for your's Ap's.
Just remember, you need to have enough licensing for both WLC.
For example, if one site has 50 AP's & the Other one has 50 Ap's, Every WLC has a minimun licensing for 100 Ap's each.
03-12-2014 02:42 PM
