Cisco Works WLSE with 1130AG
We are going to deploy a wireless solution by using 1130AG Access Point (AIR-AP1131AG-A-K9) with Cisco Works WLSE (CWWLSE-1030-K9).
The questions are:
Are there any recommendations for Cisco Works WLSE location in this building? By the way, the building has five floors and each floor has access switch that supports PoE with empty Giga ports?
Secondly, how many access points are recommended in each floor, the floor size is 37.5 x 24 m^2. And all floors are identical in the nature of building (Jobson board partition) and number of users?
THANK YOU
HASSAN
1 ACCEPTED SOLUTION
Green
Re: Cisco Works WLSE with 1130AG
Hassan:
First, the WLSE is like any other server platform, so anywhere with a suitable environment (cool, decent power/UPS, connectivity) should be OK.
Regarding recommendations for how many APs and where to put 'em .... well, that's much tougher.
The only absolutely safe answer is that it will depend on the outcome of a good site survey.
There are so many variables for any given environment, and they are almost always different, that providing an answer can only be the result of pure speculation. What that usually means is guessing to the good side and overspecifying the solution.
Even then, there are some unknown factors that you can only get with a site survey (like interference .... channels used by your neighbors, multipath potential, dead spots & such).
If you are unfamiliar with how to do a good site survey, it would pay in the long run to hire someone that is. It certainly is an added expense up-front, but the ultimate deployment will be more likely to work to your/ your customer's expectations.
Once the system is up, you can make tweaks and adjustments according to the measurements reported on the WLSE, but the primary setup shouldn't be based on a "good guess."
The number of users per AP is also somewhat variable, depending on the type of applications and the expected traffic from each user.
I've seen thirty users as an absolute max, with as few as ten for heavy traffic use. Generally speaking, somewhere around twenty users per AP for common use would be a reasonable number.
If you have users or systems that will be using 802.11b, that number may be smaller, because the AP must make accommodation for using both 802.11b and 802.11g.
More details would help, but without a good site survey, noone can really give you a firm answer.
Good Luck
Scott
Green
Hassan:
Good Luck
Scott
Thank you Mr.Scott
It was a wonderful reply and all points I am going to take in my considerations.
Thank you again
132
