CLI scripts for WLAN controller stagin
I'm wondering if anyone has ever stumbled across a staging script that I could modify to deploy a dozen controllers.  I've seen some config generators in the past, but all I'm really looking for is a script that I can go in and modify.  I am doing this more for consistancy (making sure everything that needs to be identical is identical) than anything else since GUI configuration can be accidentally misconfigured with names, etc.
Anyone know of anything?  If so, are you willing to share?
Hall of Fame Super Silver
I have built one for my
I have built one for my company, but of course can't really share it.  Started it about 7 years ago and just kept building on it to make staging fast.
One thing I can tell you to do for consistency is to build one WLC and make that 99% complete and test. Then you take that config and you manually edit it for all the other WLC's, IP address, hostnames, etc will change.  Then you either use those as boot up scripts or you go throught the startup wizard and then upload the new config.
This is how I deploy many WLC's at a time:)
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
I have never been to such
I have never been to such scenario before.Once i get will let you know.
71
