02-20-2018 09:44 AM - edited 07-05-2021 08:16 AM
Is there a way to show (from CLI) a WLAn summary similar to the WLC "Monitor" page on the GUI?
I'd like to be able to capture the WLAN's in use, and how many clients in each WLAN. I don't want details on all individual clients, just a summary.
"Show WLAN summary" does not give this; what I guess I'd like to accomplish is a "show WLAN CLIENT SUMMARY" with 10 lines, if I have 10 WLAN's. Exactly like the gui monitor "top WLAN" on the home page...
02-20-2018 10:41 AM
I just take a look and none command combination show this information.
-If I helped you somehow, please, rate it as useful.-
02-20-2018 07:49 PM
You can use "show client wlan <wlan_id>" CLI command to get what you want. You may have to issue it 10 times if you have 10 SSID
(WLC) >show client wlan ?
<WLAN Id> Enter the WLAN ID
Example
(WLC) >show client wlan 22
Number of Clients in WLAN........................ 1009
Rasika
*** Pls rate all useful responses ***
05-17-2023 05:18 AM
show client summary will show you all the clients and what WLAN they are using
05-21-2023 03:59 AM
It would help to know what model of WLC and software version you're using because AireOS and IOS-XE commands are different?
