Client got not connection to wlan over wlc 2504 on 802.11b/g
Hi everybody,
We are using a wlc 2504 with 7.6.100.0 and AP 1532e.
I have the strange observacion that only clients with 802.11n (2.4GHz) can connect to the WLAN. Clients thats works only with 802.11b/g, they can't connect to the WLAN. Affected are all machines which want to connect with 802.11b/g.
This is a MESH WLAN with 5GHz backhaul and 2.4GHz for the user.
During the debugging found the following:
*apfMsConnTask_4: May 09 11:44:40.581: 00:1b:77:b4:34:e0 Sending Assoc Response to station on BSSID 18:9c:5d:71:34:50 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: May 09 11:44:40.581: 00:1b:77:b4:34:e0 apfProcessAssocReq (apf_80211.c:8292) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*spamApTask6: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Sent 1x initiate message to multi thread task for mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Creating a PKC PMKID Cache entry for station 00:1b:77:b4:34:e0 (RSN 2)
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Adding BSSID 18:9c:5d:71:34:50 to PMKID cache at index 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: New PMKID: (16)
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584:      [0000] f6 3d 52 9f 2a de 52 90 1d a2 46 49 0f 14 f6 69
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Initiating RSN PSK to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 dot1x - moving mobile 00:1b:77:b4:34:e0 into Force Auth state
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 EAPOL Header:
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00000000: 02 03 00 5f                                       ..._
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Found an cache entry for BSSID 18:9c:5d:71:34:50 in PMKID cache at index 0 of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Starting key exchange to mobile 00:1b:77:b4:34:e0, data packets will be dropped
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Sending EAPOL-Key Message to mobile 00:1b:77:b4:34:e0
   state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_0: May 09 11:44:40.584: 00:1b:77:b4:34:e0 Allocating EAP Pkt for retransmission to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:40.585: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*Dot1x_NW_MsgTask_0: May 09 11:44:40.585: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*Dot1x_NW_MsgTask_0: May 09 11:44:40.585: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*Dot1x_NW_MsgTask_0: May 09 11:44:40.585: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:44:42.649: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:44:42.649: 00:1b:77:b4:34:e0 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:42.649: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:44:42.649: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:44:42.649: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:44:42.649: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:44:44.649: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:44:44.649: 00:1b:77:b4:34:e0 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:44.649: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:44:44.649: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:44:44.649: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:44:44.650: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:44:46.649: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Retransmit failure for EAPOL-Key M1 to mobile 00:1b:77:b4:34:e0, retransmit count 3, mscb deauth count 1
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Removing BSSID 18:9c:5d:71:34:50 from PMKID cache of station 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Setting active key cache index 0 ---> 8
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Sent Deauthenticate to mobile on BSSID 18:9c:5d:71:34:50 slot 0(caller 1x_ptsm.c:598)
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 8
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Deleting the PMK cache when de-authenticating the client.
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Global PMK Cache deletion failed.
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*dot1xMsgTask: May 09 11:44:46.649: 00:1b:77:b4:34:e0 Freeing EAP Retransmit Bufer for mobile 00:1b:77:b4:34:e0
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Reassociation received from mobile on BSSID 18:9c:5d:71:34:50
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Global 200 Clients are allowed to AP radio
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Max Client Trap Threshold: 0  cur: 1
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Applying Interface policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 1
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Re-applying interface policy for client
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2202)
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2223)
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 In processSsidIE:4795 setting Central switched to TRUE
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 In processSsidIE:4798 apVapId = 1 and Split Acl Id = 65535
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Applying site-specific Local Bridging override for station 00:1b:77:b4:34:e0 - vapId 1, site 'default-group', interface 'catodos'
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Applying Local Bridging Interface Policy for station 00:1b:77:b4:34:e0 - vlan 1, interface id 12, interface 'catodos'
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 STA - rates (8): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 STA - rates (12): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 extSuppRates  statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 Processing RSN IE type 48, length 20 for mobile 00:1b:77:b4:34:e0
*apfMsConnTask_4: May 09 11:44:52.083: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last state AUTHCHECK (2)
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 Central switch is TRUE
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 18:9c:5d:71:34:50 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 apfPemAddUser2 (apf_policy.c:333) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 apfPemAddUser2:session timeout forstation 00:1b:77:b4:34:e0 - Session Tout 1800, apfMsTimeOut '1800' and sessionTimerRunning flag is  0
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 Func: apfPemAddUser2, Ms Timeout = 1800, Session Timeout = 1800
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 Sending Assoc Response to station on BSSID 18:9c:5d:71:34:50 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: May 09 11:44:52.084: 00:1b:77:b4:34:e0 apfProcessAssocReq (apf_80211.c:8292) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*spamApTask6: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Sent 1x initiate message to multi thread task for mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Creating a PKC PMKID Cache entry for station 00:1b:77:b4:34:e0 (RSN 2)
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Adding BSSID 18:9c:5d:71:34:50 to PMKID cache at index 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: New PMKID: (16)
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087:      [0000] f6 3d 52 9f 2a de 52 90 1d a2 46 49 0f 14 f6 69
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Initiating RSN PSK to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 dot1x - moving mobile 00:1b:77:b4:34:e0 into Force Auth state
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 EAPOL Header:
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00000000: 02 03 00 5f                                       ..._
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Found an cache entry for BSSID 18:9c:5d:71:34:50 in PMKID cache at index 0 of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Starting key exchange to mobile 00:1b:77:b4:34:e0, data packets will be dropped
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Sending EAPOL-Key Message to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 Allocating EAP Pkt for retransmission to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*Dot1x_NW_MsgTask_0: May 09 11:44:52.087: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:44:54.249: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:44:54.249: 00:1b:77:b4:34:e0 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:54.249: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:44:54.249: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:44:54.249: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:44:54.249: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:44:56.249: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:44:56.249: 00:1b:77:b4:34:e0 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:56.249: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:44:56.249: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:44:56.249: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:44:56.249: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:44:58.249: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:44:58.249: 00:1b:77:b4:34:e0 Retransmit failure for EAPOL-Key M1 to mobile 00:1b:77:b4:34:e0, retransmit count 3, mscb deauth count 2
*dot1xMsgTask: May 09 11:44:58.249: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:58.249: 00:1b:77:b4:34:e0 Removing BSSID 18:9c:5d:71:34:50 from PMKID cache of station 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:44:58.249: 00:1b:77:b4:34:e0 Setting active key cache index 0 ---> 8
*dot1xMsgTask: May 09 11:44:58.250: 00:1b:77:b4:34:e0 Sent Deauthenticate to mobile on BSSID 18:9c:5d:71:34:50 slot 0(caller 1x_ptsm.c:598)
*dot1xMsgTask: May 09 11:44:58.250: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 8
*dot1xMsgTask: May 09 11:44:58.250: 00:1b:77:b4:34:e0 Deleting the PMK cache when de-authenticating the client.
*dot1xMsgTask: May 09 11:44:58.250: 00:1b:77:b4:34:e0 Global PMK Cache deletion failed.
*dot1xMsgTask: May 09 11:44:58.250: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*dot1xMsgTask: May 09 11:44:58.250: 00:1b:77:b4:34:e0 Freeing EAP Retransmit Bufer for mobile 00:1b:77:b4:34:e0
*apfMsConnTask_4: May 09 11:45:03.768: 00:1b:77:b4:34:e0 Reassociation received from mobile on BSSID 18:9c:5d:71:34:50
*apfMsConnTask_4: May 09 11:45:03.768: 00:1b:77:b4:34:e0 Global 200 Clients are allowed to AP radio
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Max Client Trap Threshold: 0  cur: 1
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Applying Interface policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 1
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Re-applying interface policy for client
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2202)
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2223)
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 In processSsidIE:4795 setting Central switched to TRUE
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 In processSsidIE:4798 apVapId = 1 and Split Acl Id = 65535
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Applying site-specific Local Bridging override for station 00:1b:77:b4:34:e0 - vapId 1, site 'default-group', interface 'catodos'
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Applying Local Bridging Interface Policy for station 00:1b:77:b4:34:e0 - vlan 1, interface id 12, interface 'catodos'
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 STA - rates (8): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 STA - rates (12): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 extSuppRates  statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Processing RSN IE type 48, length 20 for mobile 00:1b:77:b4:34:e0
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last state AUTHCHECK (2)
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Central switch is TRUE
*apfMsConnTask_4: May 09 11:45:03.769: 00:1b:77:b4:34:e0 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 18:9c:5d:71:34:50 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 apfPemAddUser2 (apf_policy.c:333) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 apfPemAddUser2:session timeout forstation 00:1b:77:b4:34:e0 - Session Tout 1800, apfMsTimeOut '1800' and sessionTimerRunning flag is  0
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 Func: apfPemAddUser2, Ms Timeout = 1800, Session Timeout = 1800
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 Sending Assoc Response to station on BSSID 18:9c:5d:71:34:50 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: May 09 11:45:03.770: 00:1b:77:b4:34:e0 apfProcessAssocReq (apf_80211.c:8292) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*spamApTask6: May 09 11:45:03.772: 00:1b:77:b4:34:e0 Sent 1x initiate message to multi thread task for mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Creating a PKC PMKID Cache entry for station 00:1b:77:b4:34:e0 (RSN 2)
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Adding BSSID 18:9c:5d:71:34:50 to PMKID cache at index 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: New PMKID: (16)
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773:      [0000] f6 3d 52 9f 2a de 52 90 1d a2 46 49 0f 14 f6 69
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Initiating RSN PSK to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 dot1x - moving mobile 00:1b:77:b4:34:e0 into Force Auth state
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 EAPOL Header:
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00000000: 02 03 00 5f                                       ..._
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Found an cache entry for BSSID 18:9c:5d:71:34:50 in PMKID cache at index 0 of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Starting key exchange to mobile 00:1b:77:b4:34:e0, data packets will be dropped
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Sending EAPOL-Key Message to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 Allocating EAP Pkt for retransmission to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*Dot1x_NW_MsgTask_0: May 09 11:45:03.773: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:45:05.849: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:45:05.849: 00:1b:77:b4:34:e0 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:05.849: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:45:05.849: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:45:05.849: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:45:05.849: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:45:07.848: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:45:07.849: 00:1b:77:b4:34:e0 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:07.849: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:45:07.849: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:45:07.849: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:45:07.849: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:45:09.848: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:45:09.849: 00:1b:77:b4:34:e0 Retransmit failure for EAPOL-Key M1 to mobile 00:1b:77:b4:34:e0, retransmit count 3, mscb deauth count 3
*dot1xMsgTask: May 09 11:45:09.849: 00:1b:77:b4:34:e0 Blacklisting (if enabled) mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:09.849: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Change state to START (0) last state 8021X_REQD (3)
*dot1xMsgTask: May 09 11:45:09.849: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Reached FAILURE: from line 5274
*dot1xMsgTask: May 09 11:45:09.849: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 9) in 10 seconds
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 Reassociation received from mobile on BSSID 18:9c:5d:71:34:50
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 Global 200 Clients are allowed to AP radio
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 Max Client Trap Threshold: 0  cur: 1
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 Applying Interface policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 1
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 Re-applying interface policy for client
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2202)
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2223)
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 In processSsidIE:4795 setting Central switched to TRUE
*apfMsConnTask_4: May 09 11:45:15.689: 00:1b:77:b4:34:e0 In processSsidIE:4798 apVapId = 1 and Split Acl Id = 65535
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Applying site-specific Local Bridging override for station 00:1b:77:b4:34:e0 - vapId 1, site 'default-group', interface 'catodos'
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Applying Local Bridging Interface Policy for station 00:1b:77:b4:34:e0 - vlan 1, interface id 12, interface 'catodos'
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 STA - rates (8): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 STA - rates (12): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 extSuppRates  statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Processing RSN IE type 48, length 20 for mobile 00:1b:77:b4:34:e0
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last state AUTHCHECK (2)
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Central switch is TRUE
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 18:9c:5d:71:34:50 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 apfPemAddUser2 (apf_policy.c:333) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 apfPemAddUser2:session timeout forstation 00:1b:77:b4:34:e0 - Session Tout 1800, apfMsTimeOut '1800' and sessionTimerRunning flag is  0
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Func: apfPemAddUser2, Ms Timeout = 1800, Session Timeout = 1800
*apfMsConnTask_4: May 09 11:45:15.690: 00:1b:77:b4:34:e0 Sending Assoc Response to station on BSSID 18:9c:5d:71:34:50 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: May 09 11:45:15.691: 00:1b:77:b4:34:e0 apfProcessAssocReq (apf_80211.c:8292) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*spamApTask6: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Sent 1x initiate message to multi thread task for mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Creating a PKC PMKID Cache entry for station 00:1b:77:b4:34:e0 (RSN 2)
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Removing BSSID 18:9c:5d:71:34:50 from PMKID cache of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Setting active key cache index 0 ---> 8
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Adding BSSID 18:9c:5d:71:34:50 to PMKID cache at index 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: New PMKID: (16)
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693:      [0000] f6 3d 52 9f 2a de 52 90 1d a2 46 49 0f 14 f6 69
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 Initiating RSN PSK to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 dot1x - moving mobile 00:1b:77:b4:34:e0 into Force Auth state
*Dot1x_NW_MsgTask_0: May 09 11:45:15.693: 00:1b:77:b4:34:e0 EAPOL Header:
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00000000: 02 03 00 5f                                       ..._
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0 Found an cache entry for BSSID 18:9c:5d:71:34:50 in PMKID cache at index 0 of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694:      [0000] f6 3d 52 9f 2a de 52 90 1d a2 46 49 0f 14 f6 69
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0 Starting key exchange to mobile 00:1b:77:b4:34:e0, data packets will be dropped
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0 Sending EAPOL-Key Message to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0 Reusing allocated memory for  EAP Pkt for retransmission to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*Dot1x_NW_MsgTask_0: May 09 11:45:15.694: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*apfMsConnTask_4: May 09 11:45:15.875: 00:1b:77:b4:34:e0 Reassociation received from mobile on BSSID 18:9c:5d:71:34:50
*apfMsConnTask_4: May 09 11:45:15.875: 00:1b:77:b4:34:e0 Global 200 Clients are allowed to AP radio
*apfMsConnTask_4: May 09 11:45:15.875: 00:1b:77:b4:34:e0 Max Client Trap Threshold: 0  cur: 1
*apfMsConnTask_4: May 09 11:45:15.875: 00:1b:77:b4:34:e0 Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Applying Interface policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 1
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Re-applying interface policy for client
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2202)
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2223)
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 In processSsidIE:4795 setting Central switched to TRUE
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 In processSsidIE:4798 apVapId = 1 and Split Acl Id = 65535
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Applying site-specific Local Bridging override for station 00:1b:77:b4:34:e0 - vapId 1, site 'default-group', interface 'catodos'
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Applying Local Bridging Interface Policy for station 00:1b:77:b4:34:e0 - vlan 1, interface id 12, interface 'catodos'
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 STA - rates (8): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 STA - rates (12): 2 4 11 22 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 extSuppRates  statusCode is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Processing RSN IE type 48, length 20 for mobile 00:1b:77:b4:34:e0
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Initializing policy
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Change state to AUTHCHECK (2) last state 8021X_REQD (3)
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last state AUTHCHECK (2)
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Central switch is TRUE
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 18:9c:5d:71:34:50 vapId 1 apVapId 1 flex-acl-name:
*apfMsConnTask_4: May 09 11:45:15.876: 00:1b:77:b4:34:e0 apfPemAddUser2 (apf_policy.c:333) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*apfMsConnTask_4: May 09 11:45:15.877: 00:1b:77:b4:34:e0 apfPemAddUser2:session timeout forstation 00:1b:77:b4:34:e0 - Session Tout 1800, apfMsTimeOut '1800' and sessionTimerRunning flag is  0
*apfMsConnTask_4: May 09 11:45:15.877: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_4: May 09 11:45:15.877: 00:1b:77:b4:34:e0 Func: apfPemAddUser2, Ms Timeout = 1800, Session Timeout = 1800
*apfMsConnTask_4: May 09 11:45:15.877: 00:1b:77:b4:34:e0 Sending Assoc Response to station on BSSID 18:9c:5d:71:34:50 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: May 09 11:45:15.877: 00:1b:77:b4:34:e0 apfProcessAssocReq (apf_80211.c:8292) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Associated
*spamApTask6: May 09 11:45:15.878: 00:1b:77:b4:34:e0 Sent 1x initiate message to multi thread task for mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Creating a PKC PMKID Cache entry for station 00:1b:77:b4:34:e0 (RSN 2)
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Removing BSSID 18:9c:5d:71:34:50 from PMKID cache of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Setting active key cache index 0 ---> 8
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Adding BSSID 18:9c:5d:71:34:50 to PMKID cache at index 0 for station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: New PMKID: (16)
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879:      [0000] f6 3d 52 9f 2a de 52 90 1d a2 46 49 0f 14 f6 69
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Initiating RSN PSK to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 EAP-PARAM Debug - eap-params for Wlan-Id :1 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 dot1x - moving mobile 00:1b:77:b4:34:e0 into Force Auth state
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 EAPOL Header:
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00000000: 02 03 00 5f                                       ..._
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Found an cache entry for BSSID 18:9c:5d:71:34:50 in PMKID cache at index 0 of station 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Starting key exchange to mobile 00:1b:77:b4:34:e0, data packets will be dropped
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Sending EAPOL-Key Message to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 Reusing allocated memory for  EAP Pkt for retransmission to mobile 00:1b:77:b4:34:e0
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*Dot1x_NW_MsgTask_0: May 09 11:45:15.879: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:45:18.048: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:45:18.049: 00:1b:77:b4:34:e0 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:18.049: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:45:18.049: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:45:18.049: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:45:18.049: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:45:20.049: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:45:20.049: 00:1b:77:b4:34:e0 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:20.049: 00:1b:77:b4:34:e0 mscb->apfMsLwappLradNhMac = 78:da:6e:59:c9:8c mscb->apfMsLradSlotId = 0 mscb->apfMsLradJumbo = 0 mscb->apfMsintIfNum = 1
*dot1xMsgTask: May 09 11:45:20.049: 00:1b:77:b4:34:e0  mscb->apfMsBssid = 18:9c:5d:71:34:50 mscb->apfMsAddress = 00:1b:77:b4:34:e0 mscb->apfMsApVapId = 1
*dot1xMsgTask: May 09 11:45:20.049: 00:1b:77:b4:34:e0  dot1xcb->snapOrg = 00 00 00 dot1xcb->eapolWepBit = 0 mscb->apfMsLwappLradVlanId = 0 mscb->apfMsLwappMwarInet.ipv4.addr = -1062679171
*dot1xMsgTask: May 09 11:45:20.049: 00:1b:77:b4:34:e0  mscb->apfMsLwappMwarPort = 5246 mscb->apfMsLwappLradInet.ipv4.addr = -1062679163 mscb->apfMsLwappLradPort = 40089
*osapiBsnTimer: May 09 11:45:22.048: 00:1b:77:b4:34:e0 802.1x 'timeoutEvt' Timer expired for station 00:1b:77:b4:34:e0 and for message = M2
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Retransmit failure for EAPOL-Key M1 to mobile 00:1b:77:b4:34:e0, retransmit count 3, mscb deauth count 0
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Resetting MSCB PMK Cache Entry 0 for station 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Removing BSSID 18:9c:5d:71:34:50 from PMKID cache of station 00:1b:77:b4:34:e0
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Setting active key cache index 0 ---> 8
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Sent Deauthenticate to mobile on BSSID 18:9c:5d:71:34:50 slot 0(caller 1x_ptsm.c:598)
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Setting active key cache index 8 ---> 8
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Deleting the PMK cache when de-authenticating the client.
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Global PMK Cache deletion failed.
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*dot1xMsgTask: May 09 11:45:22.049: 00:1b:77:b4:34:e0 Freeing EAP Retransmit Bufer for mobile 00:1b:77:b4:34:e0
*osapiBsnTimer: May 09 11:45:32.048: 00:1b:77:b4:34:e0 apfMsExpireCallback (apf_ms.c:625) Expiring Mobile!
*apfReceiveTask: May 09 11:45:32.049: 00:1b:77:b4:34:e0 apfMsExpireMobileStation (apf_ms.c:6632) Changing state for mobile 00:1b:77:b4:34:e0 on AP 18:9c:5d:71:34:50 from Associated to Disassociated
*apfReceiveTask: May 09 11:45:32.049: 00:1b:77:b4:34:e0 Scheduling deletion of Mobile Station:  (callerId: 45) in 10 seconds
Thanks for any advice
  • Getting Started with Wireless
Hall of Fame Super Gold
In some of the big name
In some of the big name brands of wireless, there is "no such thing" as 802.11n on a 2.4 Ghz.  No such thing because Cisco won't allow you (any more) to do channel bonding of 2.4 Ghz.  It doesn't make any sense to bond an already restricted 2.4 Ghz non-overlapping channel (three) and squeeze this number down to two.
Can you check to ensure that the data rates for 802.11b are enabled?  Maybe someone disabled data rates from 1 Mbps to 11 Mbps.
In 802.11b, all data rates
In 802.11b, all data rates are enabled
Do you have MFP configured to
Do you have MFP configured to mandatory?  Your b/g devices are most likely much older and may not support MFP.
John
489
