Community Member
Clients connectivity issue
Hi all,
We are having WLC 4404(6.0.202.0) and AP's 1131 and 1242 . We have some 75 wireless clients out of which 20 laptops are having connectivity issue. When a client connects  first time they will get limited connectivity . after disconnect and connect it again it will start to work .
The below is the debug for both scenariao's
Limited access debug:
(Cisco Controller) >*Jan 22 15:20:05.523: f4:b7:e2:05:51:95 Association received
from mobile on AP 00:1e:7a:70:ea:f0
*Jan 22 15:20:05.523: f4:b7:e2:05:51:95 Applying site-specific IPv6 override for
station f4:b7:e2:05:51:95 - vapId 1, site 'default-group', interface 'quarantin
e'
*Jan 22 15:20:05.523: f4:b7:e2:05:51:95 Applying IPv6 Interface Policy for stati
on f4:b7:e2:05:51:95 - vlan 60, interface id 10, interface 'quarantine'
*Jan 22 15:20:05.523: f4:b7:e2:05:51:95 STA - rates (7): 150 24 36 48 72 96 108
0 0 0 0 0 0 0 0 0
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Deleted mobile LWA
PP rule on AP [00:1e:f7:75:00:80]
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 Updated location for station old AP 00:1
e:f7:75:00:80-0, new AP 00:1e:7a:70:ea:f0-0
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Applied RADIUS ove
rride policy
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Adding Fast Path r
ule
  type = Airespace AP Client
  on AP 00:1e:7a:70:ea:f0, slot 0, interface = 29, QOS = 0
  ACL Id = 255, Jumbo Frames = NO,
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Successfully plumb
ed mobile rule (ACL ID 255)
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Plumbed mobile LWA
PP rule on AP 00:1e:7a:70:ea:f0 vapId 1 apVapId 1
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Change state to RU
N (20) last state RUN (20)
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 apfPemAddUser2 (apf_policy.c:213) Changi
ng state for mobile f4:b7:e2:05:51:95 on AP 00:1e:7a:70:ea:f0 from Associated to
Associated
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 Stopping deletion of Mobile Station: (ca
llerId: 48)
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 Sending Assoc Response to station on BSS
ID 00:1e:7a:70:ea:f0 (status 0) Vap Id 1 Slot 0
*Jan 22 15:20:05.524: f4:b7:e2:05:51:95 apfProcessAssocReq (apf_80211.c:4391) Ch
anging state for mobile f4:b7:e2:05:51:95 on AP 00:1e:7a:70:ea:f0 from Associate
d to Associated
*Jan 22 15:20:05.530: f4:b7:e2:05:51:95 10.91.19.188 Removed NPU entry.
SSID disconnect and connect:(Working)
e'
0 0 0 0 0 0 0 0 0
rride policy
ule
Associated
llerId: 48)
d to Associated
(Cisco Controller) >*Jan 22 15:20:05.538: f4:b7:e2:05:51:95 10.91.19.188 Added N
PU entry of type 1, dtlFlags 0x0
*Jan 22 15:23:03.383: f4:b7:e2:05:51:95 Association received from mobile on AP 0
0:1e:f7:75:00:80
*Jan 22 15:23:03.383: f4:b7:e2:05:51:95 Applying site-specific IPv6 override for
e'
*Jan 22 15:23:03.383: f4:b7:e2:05:51:95 Applying IPv6 Interface Policy for stati
*Jan 22 15:23:03.383: f4:b7:e2:05:51:95 STA - rates (7): 150 24 36 48 72 96 108
0 0 0 0 0 0 0 0 0
*Jan 22 15:23:03.383: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Deleted mobile LWA
PP rule on AP [00:1e:7a:70:ea:f0]
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 Updated location for station old AP 00:1
e:7a:70:ea:f0-0, new AP 00:1e:f7:75:00:80-0
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Applied RADIUS ove
rride policy
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Adding Fast Path r
ule
  on AP 00:1e:f7:75:00:80, slot 0, interface = 29, QOS = 0
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Successfully plumb
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Plumbed mobile LWA
PP rule on AP 00:1e:f7:75:00:80 vapId 1 apVapId 1
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 10.91.19.188 RUN (20) Change state to RU
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 apfPemAddUser2 (apf_policy.c:213) Changi
ng state for mobile f4:b7:e2:05:51:95 on AP 00:1e:f7:75:00:80 from Associated to
Associated
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 Stopping deletion of Mobile Station: (ca
llerId: 48)
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 Sending Assoc Response to station on BSS
ID 00:1e:f7:75:00:80 (status 0) Vap Id 1 Slot 0
*Jan 22 15:23:03.384: f4:b7:e2:05:51:95 apfProcessAssocReq (apf_80211.c:4391) Ch
anging state for mobile f4:b7:e2:05:51:95 on AP 00:1e:f7:75:00:80 from Associate
d to Associated
*Jan 22 15:23:03.389: f4:b7:e2:05:51:95 10.91.19.188 Removed NPU entry.
*Jan 22 15:23:03.398: f4:b7:e2:05:51:95 10.91.19.188 Added NPU entry of type 1,
dtlFlags 0x0
*Jan 22 15:23:03.418: f4:b7:e2:05:51:95 DHCP received op BOOTREQUEST (1) (len 30
8, port 29, encap 0xec03)
*Jan 22 15:23:03.418: f4:b7:e2:05:51:95 DHCP selecting relay 1 - control block s
ettings:
                        dhcpServer: 10.91.15.252, dhcpNetmask: 0.0.0.0,
                        dhcpGateway: 0.0.0.0, dhcpRelay: 10.91.19.2  VLAN: 60
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP selected relay 1 - 10.91.15.252 (lo
cal address 10.91.19.2, gateway 10.91.19.254, VLAN 60, port 29)
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP transmitting DHCP DISCOVER (1)
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP   op: BOOTREQUEST, htype: Ethernet,
hlen: 6, hops: 1
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP   xid: 0xf133f03 (252919555), secs:
0, flags: 0
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP   chaddr: f4:b7:e2:05:51:95
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Jan 22 15:23:03.419: f4:b7:e2:05:51:95 DHCP   siaddr: 0.0.0.0,  giaddr: 10.91.1
9.2
*Jan 22 15:23:03.420: f4:b7:e2:05:51:95 DHCP sending REQUEST to 10.91.19.254 (le
n 350, port 29, vlan 60)
*Jan 22 15:23:03.420: f4:b7:e2:05:51:95 DHCP selecting relay 2 - control block s
ettings:
*Jan 22 15:23:03.420: f4:b7:e2:05:51:95 DHCP selected relay 2 - NONE
*Jan 22 15:23:03.420: f4:b7:e2:05:51:95 DHCP received op BOOTREPLY (2) (len 330,
port 29, encap 0xec00)
*Jan 22 15:23:03.421: f4:b7:e2:05:51:95 DHCP sending REPLY to STA (len 442, port
29, vlan 10)
*Jan 22 15:23:03.421: f4:b7:e2:05:51:95 DHCP transmitting DHCP OFFER (2)
*Jan 22 15:23:03.421: f4:b7:e2:05:51:95 DHCP   op: BOOTREPLY, htype: Ethernet, h
len: 6, hops: 0
*Jan 22 15:23:03.421: f4:b7:e2:05:51:95 DHCP   xid: 0xf133f03 (252919555), secs:
0, flags: 0
*Jan 22 15:23:03.421: f4:b7:e2:05:51:95 DHCP   chaddr: f4:b7:e2:05:51:95
*Jan 22 15:23:03.421: f4:b7:e2:05:51:95 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.91.1
9.188
*Jan 22 15:23:03.422: f4:b7:e2:05:51:95 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*Jan 22 15:23:03.422: f4:b7:e2:05:51:95 DHCP   server id: 1.1.1.1  rcvd server i
d: 10.91.15.252
*Jan 22 15:23:03.423: f4:b7:e2:05:51:95 DHCP received op BOOTREQUEST (1) (len 34
*Jan 22 15:23:03.423: f4:b7:e2:05:51:95 DHCP selecting relay 1 - control block s
ettings:
*Jan 22 15:23:03.423: f4:b7:e2:05:51:95 DHCP selected relay 1 - 10.91.15.252 (lo
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP transmitting DHCP REQUEST (3)
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   op: BOOTREQUEST, htype: Ethernet,
hlen: 6, hops: 1
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   xid: 0xf133f03 (252919555), secs:
0, flags: 0
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   chaddr: f4:b7:e2:05:51:95
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   siaddr: 0.0.0.0,  giaddr: 10.91.1
9.2
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   requested ip: 10.91.19.188
*Jan 22 15:23:03.424: f4:b7:e2:05:51:95 DHCP   server id: 10.91.15.252  rcvd ser
ver id: 1.1.1.1
*Jan 22 15:23:03.425: f4:b7:e2:05:51:95 DHCP sending REQUEST to 10.91.19.254 (le
n 390, port 29, vlan 60)
*Jan 22 15:23:03.425: f4:b7:e2:05:51:95 DHCP selecting relay 2 - control block s
ettings:
*Jan 22 15:23:03.425: f4:b7:e2:05:51:95 DHCP selected relay 2 - NONE
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP received op BOOTREPLY (2) (len 335,
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP sending REPLY to STA (len 442, port
29, vlan 10)
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP transmitting DHCP ACK (5)
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP   op: BOOTREPLY, htype: Ethernet, h
len: 6, hops: 0
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP   xid: 0xf133f03 (252919555), secs:
0, flags: 0
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP   chaddr: f4:b7:e2:05:51:95
*Jan 22 15:23:03.426: f4:b7:e2:05:51:95 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.91.1
9.188
*Jan 22 15:23:03.427: f4:b7:e2:05:51:95 DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*Jan 22 15:23:03.427: f4:b7:e2:05:51:95 DHCP   server id: 1.1.1.1  rcvd server i
d: 10.91.15.252
Kindly suggest..
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Clients connectivity issue
Might be that they keep their IP address but while they are in sleep, the lease expires and the IP address is leased to another device? Or maybe the WLC keeps the IP address while the client is in idle or sleeping client state and the device awakes and wants a new address? You have to look at the client state on the WLC and see what the IP address if the client is. Then look at the machine when it wakes up... Does it have an IP address or not and also look at the DHCP scope for the lease time and maybe the routers arp table to see if there are duplicate MAC address tied to the IP address.
-Scott
VIP Purple
HI vijay,
I will recomamnd to update the WLC software,
6.0.202.0 is very old.
4400 series WLC last support is 7.0.x
Please upgrade and then check it again.
Dont forget to rate helpful posts
You need to take a closer look at what's happening.... when this happens, what does the radius server show, what does the WLC show for the client under the monitoring tab?  The thing that you need to look at is what interface did the WLC put that client on, because it can of left them in your quarantine interface.  When using AP Groups also, it becomes a challenge because one code it works fine, others, it may not.  I usually have created a black-hole interface and assign that to the WLAN interface and use AP Groups to assign the correct interface.... well it doesn't work all the time.  Also when using AP Groups
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Community Member
Hi Mr.Scott,
Here we are using only PSK . No AAA server and AP groups are configured .
Post your show wlan
Scott
-Scott
Community Member
The output is below ,
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... ------
Network Name (SSID).............................. -----
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  NAC-State...................................... Disabled
  Quarantine VLAN................................ 0
Number of Active Clients......................... 109
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ quarantine
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
--More-- or (q)uit
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 2
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System (Allow shared key)
--More-- or (q)uit
   Static WEP Keys............................... Enabled
        Key Index:...................................... 1
        Encryption:..................................... 40-bit WEP
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   CKIP ......................................... Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Learn IP Address....................... Enabled
   Infrastructure MFP protection................. Enabled (Global Infrastructure
MFP Disabled)
   Client MFP.................................... Optional but inactive (WPA2 no
t configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Band Select...................................... Enabled
Load Balancing................................... Enabled
Mobility Anchor List
--More-- or (q)uit
WLAN ID     IP Address            Status
Your using WEP? Also I would disable client load balancing which is another big issue in your WLAN setting.
-Scott
Community Member
Yes , this is in one of our client location . will Disabling the client load balancing help to resolve it ? Previously they were runing with 4.x series software. Recently they upgraded with this release . After upgrade only they are facing this issue.
Yes that can cause issue... disable that and see if that helps or not.
Scott
-Scott
Community Member
Thanks Mr.Scott , we will try that option and will update the same.
Sounds good.
Scott
-Scott
Community Member
Hi Scott,
We have tried the below options ,
1. Disabled client load balancing and infra MFP
2. Upgraded with 7.0.240 for WLC
But still , the issue is happening for the laptops in sleep mode . Means , once the sleeping clients are on , first time they are showing as " limited connectivity " . But once we disconnnect and connect again it will work . Any idea on why the Power save clients are showing as limited connectivity.
Thanks..
-Scott
Community Member
Ok.Thanks for the suggestion  Scott . We will check that tomorrow and will update.
Keep us posted
Scott
-Scott
Community Member
Hi Scott ,
Sorry for posting late... It was just issue with clients driver . Customer was having Ralink wireless adapter with version of 3.2.14 . After updating with latest version 5.0.19  issue got resolved.
Thanks for the follow up and posting the solution to the issue. This might help others out in the future.
-Scott
VIP Purple
7.0.241.x (7.0 MR5 Pre-Release) is available via TAC (see below). Go for this code & then see what's the behaviour.
https://supportforums.cisco.com/docs/DOC-39432
Rasika
*** Pls rate all useful responses ****
Do you happen to have MFP(management frame protection) enable on your client and is your client supporting CCXv5(CCXv4).
If not supporting CCXv5(CCXv4) then please try disabling the MFP and try again.
1133
