Clients keep deauthenticating from autonomous AP 1602E
Hi Guys,
I've got 5 autonomous APs 1602E deployed and i'm testing them now, however, I've met one problem: the clients keep deauthenticating from the AP, clients can just connect to the first AP the the other 4 keeps showing the logs as bellows:
Nov 27 15:51:02.135: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Reassociated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:02.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:04.695: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:04.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:06.343: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:06.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:08.447: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:08.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:10.415: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:10.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:12.495: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:12.815: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:14.594: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:14.814: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
Nov 27 15:51:16.662: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   e4ce.8fb9.27e0 Associated KEY_MGMT[WPAv2 PSK]
Nov 27 15:51:16.814: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4ce.8fb9.27e0 Reason: Previous authentication no longer valid
It really troubles me a lot, here is my configuration and show version info of the AP:
SIAS-PD-C1602E-01#
SIAS-PD-C1602E-01#sh run
Building configuration...
Current configuration : 2243 bytes
! Last configuration change at 02:00:42 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname SIAS-PD-C1602E-01
logging rate-limit console 9
enable secret 5 $1$P/z5$V9aL2cCWi7faKCoOyqdF7/
no aaa new-model
ip cef
dot11 syslog
dot11 vlan-name Wireless-2GHz vlan 50
dot11 ssid SIAS-AP-2GHz
   vlan 50
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 115A495107040C5E56797D
dot11 wpa handshake timeout 2000
username Cisco privilege 15 password 7 123A0C041104
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 50 mode ciphers aes-ccm
ssid SIAS-AP-2GHz
antenna gain 0
stbc
beamform ofdm
station-role root
no dot11 extension aironet
interface Dot11Radio0.50
description For Wireless LAN 2GHz User
encapsulation dot1Q 50 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
encryption vlan 60 mode ciphers aes-ccm
antenna gain 4
stbc
station-role root
bridge-group 1
interface GigabitEthernet0
description Ge int to SW2960SPOE-01
no ip address
duplex auto
speed auto
interface GigabitEthernet0.50
description 2GHz Wireless User
bridge-group 1
interface BVI1
ip address 10.169.20.1 255.255.255.0
ip default-gateway 10.169.20.254
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 10.169.20.254
bridge 1 route ip
line con 0
password 7 096F471A1A0A
line vty 0 4
exec-timeout 5 0
password 7 062506324F41
login
transport input all
end
SIAS-PD-C1602E-01#
SIAS-PD-C1602E-01#show version
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 04:30 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
SIAS-PD-C1602E-01 uptime is 2 hours, 21 minutes
System image file is "flash:/ap1g2-k9w7-mx.152-2.JB/ap1g2-k9w7-mx.152-2.JB"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1602E-C-K9    (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1726X71M
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F8:72:EA:7C:A0:2B
Part Number                          : 73-14508-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17227R3C
Top Assembly Part Number             : 800-38553-01
Top Assembly Serial Number           : FGL1726X71M
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP1602E-C-K9
Configuration register is 0xF
SIAS-PD-C1602E-01#
Can anybody help me with that? THX!!
Savi
1 ACCEPTED SOLUTION
VIP Purple
Hi Savi,
High error counters on radio interfaces on the client, the access point or bridge indicate the effects of RF interference.
Certain clients using WPA/WPA2 key management and power save can take many attempts to authenticate or, in some cases, fail to authenticate. Any SSID that is defined to use authentication key-management WPA, together with clients using power save mode and authenticating using WPA/WPA2, can experience this problem.
so Try this command and check it.
If still not works then please identify your RF interference.
Dont forget to rate hlpful post.
VIP Purple
HI Savi,
First these types error occurs when u have singnal problem
2nd: please disable aironet extension by using this command:
Under the dot11radio interface you should enter;
'no dot11 extension aironet' command.This command works unless the radio interface is in bridge or wgb mode.
Hi Sandeep,
Thanks for your reply.
I just stand under the AP, the signal seems good and i've already tried the "no dot11 extension aironet" as i posted above. Howevere, the situation does not get better with both iphone and samsung.
Savi
VIP Purple
Hi Savi,
Hi Sandeep,
I think the error has little to do with the power save because phones can connect to the AP1 succfully but cannot connect to any of the other APs. After rebooting all of the APs, phones can connect to AP5 if AP5 boots up first. And i have already tried the "dot11 wpa handshake timeout 2000" but no use. I'm wondering if the 5 APs will interfere each other themselves.
Savi
Update here: I just restarted the AP several times and then everything goes fine... So i think i should contact the TAC for the support.
997
