Clients through Mesh AP are unable to get IP
Dears
I am having 6 APs.Mesh is established and in all APs "Backhaul Client Access" is enabled.Problem is clients are able to get IP through Roof Top AP but not able to get ip from mesh AP.Is there noption i missed ? or any option i require to check or uncheck.
Please reply
Hall of Fame Super Silver
Re: Clients through Mesh AP are unable to get IP
So yoiu enabled "Backhaul Client Access" globally on the wlc. So now only 802.11a access will be allowed. So your clients are using 802.11a and not 802.11b/g correct?
-Scott
Dear
I am sure you are right.But did we enable any client Acess as globally after mesh or keep it as default
If you leave it default then only 802.11bg will be used for client access, otherwise if enabled, only 802.11a will be used for client access.
-Scott
But clients are not able to get IP address through MESH APs....but through RAP APs clients are able to get IP address
Do the client associate to 802.11a or 802.11b/g from the RAP?
-Scott
281
