02-15-2012 04:25 PM - edited 07-03-2021 09:35 PM
Hi all
just been given a CAP 3502i access point, try to logon and configure the password, but not accept the config t. Is it because this equipted with Light weigh mode IOS?
I followed the link bellow: http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/command/reference/cr12410b-chap1.html
Roy
Solved! Go to Solution.
02-16-2012 08:49 AM
Has the AP joined the WLC :
What you can do is you go to wireless - > select the AP and override global credentialss to set a password for it specifically
02-15-2012 04:33 PM
Yes. It's because it's runnig CAPWAP IOS (default).
02-15-2012 04:42 PM
Thanks for prompt reply.
is any way that provide me to telnet or use http to access to it, since it will be send to remote site, I would like to have some control if something goes wrong with it one day?
02-15-2012 04:44 PM
3502 series APs are CAPWAP only so you manage/troubleshoot from the WLC and not the AP directly.
02-16-2012 08:49 AM
02-22-2012 11:48 AM
Thanks Tuhin for sharing this information 5+
Vinay Sharma
Community manager
