Community Member
CONFIGURACION AIR-AP2802I-A-K9
Hola buen dia tengo un problema requiero configurar mi AP AIR-AP2802I-A-K9, segun las espicificaciones no requiero de alguna controladora, conecto mi AP a un switch el cual tiene DHCP, por medio del CLI reviso que direccion le asigna a mi AP por medio del comando: show capwap ip config, y este me arroja la 192.168.1.45, trato de abriri un explorador pero esta no accede a la configuracion del AP, alguien tiene idea de como puedo configurar mi ap ya sea por medio de la web o de CLI.
Dejo algunas capturas de CLI.
[*03/15/2017 00:14:58.5062] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:15:07.9611] CAPWAP State: Discovery
[*03/15/2017 00:15:08.0067] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:15:17.4638] CAPWAP State: Discovery
[*03/15/2017 00:15:17.5096] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:15:26.9665] CAPWAP State: Discovery
[*03/15/2017 00:15:27.0123] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:15:36.4693] CAPWAP State: Discovery
[*03/15/2017 00:15:36.5154] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:15:45.9720] CAPWAP State: Discovery
[*03/15/2017 00:15:46.0648] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:15:55.4747] CAPWAP State: Discovery
[*03/15/2017 00:15:55.5265] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[*03/15/2017 00:16:04.9775] CAPWAP State: Discovery
[*03/15/2017 00:16:05.0245] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
[03/15/2017 00:16:11.8100] wired0 emac 2: link down
[03/15/2017 00:16:11.8700] wired0: link down
[*03/15/2017 00:16:14.7669] ethernet_port wired0, ip 192.168.1.64, netmask 255.2        55.255.0, gw 192.168.1.254, mtu 1500, bcast 192.168.1.255, dns1 192.168.1.254, d
espero me pedan apoyar.
Victor,
Victor,
¿Esperas que el ap funcione como Mobility Express?
Entonces no necesitamos ningún controlador. Sin embargo para confirmar si usted tiene imagen expresa de la movilidad, actualícenos por favor la salida abajo.
> show version
También tenga por favor un botín en el acoplamiento abajo que le da idea básica de la disposición expresa de la movilidad.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
Sreejith
Community Member
Lo que Deseo saber es si
Lo que Deseo saber es si requiero alguna controladora para no cambiar su IOS.
No soy experto en cisco, solo deseo saber si realmente requiero alguna controladora para que mi ap se asocie y funcione.
Por el momento no tengo el equipo a la mano, pero copie my terminal y esto es lo que me salio al darle un #sh run
#sh run
AP Name                    : Not Configured
Admin State                : Enabled
AP Mode                    : Local
AP Submode                 : None
Reboot Reason              : Invalid Config File
Primary controller name    :
Primary controller IP      : 0.0.0.0
Secondary controller name  :
Secondary controller IP    : 0.0.0.0
Tertiary controller name   :
Tertiary controller IP     : 0.0.0.0
AP join priority           : 1
Last Joined Controller name:
DTLS Encryption State      : Disabled
Discovery Timer            : 10
Heartbeat Timer            : 30
CDP State                  : Enabled
Watchdog monitoring        : Enabled
RRM State                  : Enabled
LSC State                  : Disabled
SSH State                  : Disabled
Usted no necesita un
Usted no necesita un controlador si su ap es la movilidad ap expresar. Para verificar que, pediría para ejecutar el siguiente comando.
show version
Community Member
Re: Victor,
ESte es
#sh version
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
            Cisco Systems, Inc.
            170 West Tasman Drive
            San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More-- fgrep: /storage/base_capwap_cfg_info: No such file or directory
[*03/15/2017 02:07:48.7647] waiting for uplink IP address and reachable default gateway
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
--More-- [*03/15/2017 02:07:53.7655] waiting for uplink IP address and reachable default gateway
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
--More-- [*03/15/2017 02:07:58.7664] waiting for uplink IP address and reachable default gateway
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
Cisco AP Software, (ap3g3), [cheetah-build:/local/build/JENKINS/workspace/8.2MR4-barbados-cco]
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon Dec  5 18:52:58 PST 2016
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version
 uptime is 0 days, 0 hours, 2 minutes
Last reload time   : Wed Mar 15 02:05:14 UTC 2017
Last reload reason : 0: unknown
cisco AIR-AP2802I-A-K9 ARMv7 Processor rev 1 (v7l) with 1030596/721412K bytes of memory.
Processor board ID FGL2112A443
AP Running Image     : 8.2.141.0
Primary Boot Image   : 8.2.141.0
Backup Boot Image    : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
Base ethernet MAC Address            : 2C:5A:0F:ED:21:90
Part Number                          : 73-100821-03
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FDO21102HMP
Top Assembly Part Number             : 068-100534-01
Top Assembly Serial Number           : FGL2112A443
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP2802I-A-K9
#[*03/15/2017 02:08:03.7673] waiting for uplink IP address and reachable default gateway
[*03/15/2017 02:08:08.7682] waiting for uplink IP address and reachable default gateway
Hola.
Hola.
Es necesario que compartas el output del comando show version del AP y te podemos decir si lo necesitas o no.
Community Member
Re: Hola.
ESte es
#sh version
            Cisco Systems, Inc.
export@cisco.com.
2 802.11 Radios
NSS FW version :
Community Member
Re: Hola.
Hola Victorvar buenas tardes, llegaste a solucionar tu inconveniente? porque yo tengo el mismo problema con mi AC AIR-AP2802i-A-K9
Community Member
Re: Hola.
Hola, con la imagen actual si requieres de una controladora, ya que en el output del show version no aparecen estos parámetros, lo cual indica que esta en modo ligero:
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
Lo que tienes que hacer es cambiar la imagen a Mobility Express, de esta forma, incluso tu AP puede hacer la función de controladora y darle servicio a otros APs en modo ligero. Puedes encontrar el procedimiento para el cambio de imagen en esta liga:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
Solo tienes que descargar la imagen de cisco.com y tener un servidor tftp en tu máquina, te recomiendo el tftpd32, el comando a ejecutar es:
AP#ap-type mobility-express tftp://
Saludos.
Community Member
Re: CONFIGURACION AIR-AP2802I-A-K9
Hola buen dia, lo que tienes que hacer es cargarle una version para convertir el AP en autonomo, hay varias maneras de cargarle la version, y despues de eso podras configurar el AP de forma autonoma
https://www.cisco.com/c/es_mx/support/docs/wireless-mobility/service-set-identifier-ssid/116118-configure-ap-ssid-ios.html
927
