Configuration for BVI1 interface
Hello to everyone,
I am trying to setup a Cisco 1801w.
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid cisco
vlan 1
authentication open
authentication key-management wpa optional
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
power local cck 50
power local ofdm 30
channel 2462
station-role root
interface Dot11Radio0.1
description Cisco Open
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 spanning-disabled
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.0.1.1 255.255.255.0
bridge 1 route ip
interface FastEthernet0
no ip address
bridge-group 1
I do not know if i have understood the concept of the BVI1 interface, I think that if i assigned an IP to the BVI interface this would apply to every interface within the same bridge group that belongs to the VLAN in this case vlan 1 nevertheless the vlan status is UP but protocol link is down.
Why the vlan1 is not changing the status protocol link to up since there is a physical port that belongs to it? Do i need to setup a different ip address to every interface in the same bridge group?  I need to bridge the wireless interface to my FastEthernet 0 that is my internal network.
Thanks in advance.
This should ve worked.
Please check if Fa0 is a Layer 3or Layer 2 port.
Thankd for your reply.
I have checked the interface and I believe that is layer 3 since there is no switchport command for this interface.  I have tried creating a subinterface and assingning encapsulation with native vlan but I cant ping to my gateway.  There is no additional Fastethernet port that supports bridging.
as the subinterface on f0 did not do the trick, what about bridging to a port between f1-8 as I think they operate at layer 2.
When you created the sub-interface, did you add it to the bridge group 1 as well?
interface FastEthernet0.1
bridge-group 1
As you have assigned vlan1 IP to BVI1 and created subinterface for dot110 and that is dot110.1 similiarly you should create fastethernet0.1 subinterface as well and map bridge-group 1 with that too to get it work.
Thanks to everyone for your replies.
About trying a different port, I tried to do that nevertheless other ports beside the fastethernet 0 does not support bridging and I have already done the subinterface for the F0.
I think that is hardware issue related problem since I reset to factory default and start over with the same configuration and it did work without adding a subinterface for the F0, I just added the F0 to the bridge-group 1 and no ip address.  The problem is that after a couple of minutes the SSID stopped promoting.
I tried with another router, same model and same configuration.  It did work for a while but the client disassociatted from the SSID and when I tried to connect again Windows started saying it can not connect to SSID.
I made a ping to internet an it worked from client connected to SSID and from router.
I believe that it is a hardware issue since these routers are about 8 years old and have stored in a bad conditions.  I cannot figure out what else could be giving me these problems.
If you have any hint that confirm my theory I will appreciate it.
Thanks.
Try the command "bridge 1 protocol ieee".
Regards.
922
