11-21-2011 09:44 PM - edited 07-03-2021 09:06 PM
I am working on Cisco 5508 WLC having 3310 MSE and 3502 APs, Now i have to configure the 5 Ghz and have b/g/n radio on, as per my ragulatory domain.
can any one help me in this.
M.Bilal
Solved! Go to Solution.
11-23-2011 08:26 AM
B/G/N used 2.4 GHz... it will not use 5 GHz.. we cannot do it!! please google to get more info on it!! like wat uses wat!!
Surendra
11-23-2011 08:27 AM
You can't achieve that speed on the 2.4ghz. What is required for max of 300mbps is the use of 40mhz channel width. Under the wireless / 802.11a/n / DCA you see an option for 20mhz and 40mhz. If you don't have that option on the 2.4ghz then you will never achieve 300mbps.
Sent from my iPhone
11-21-2011 10:04 PM
Hi MB,
Not sure I follow.
1. Did you enable Clean Air on the WLC ?
2. Do you have WCS ?
11-21-2011 10:14 PM
1- yes i have enable Clean Air on WLC.
2- and also using WCS.
All other function is perfectly working.
11-21-2011 10:18 PM
OK so what is the nature of your problem?
11-21-2011 10:23 PM
What domain is your controller configure for now
What is the full model of your access points (3500s)
What domain do you live in
11-21-2011 10:32 PM
1- Yes my controller is configured as per my regulatory domain
2- My AP model is AIR-CAP3502E-EK9
3- My domain is Pakistan
it is possible to configure 5 Ghz having b/g/n enable radio?
11-21-2011 10:38 PM
The 3502 has 2 WiFi chips / radios.
1 - Is a 2.4 GHz 802.11 b/g/n
1 - Is a 5 GHz 802.11a/n
Can you enable both radios -- If you domain allows it, yes. Which I beileve E does. Are you having problems enabling both ?
11-21-2011 10:46 PM
Yes I have enable all a/b/g/n but (a radio) is down.
i dont know why !
11-21-2011 10:54 PM
Check and make sure your A network is enabled.
click on wireless tab -- 802.11a -- network
see attached pix
11-21-2011 10:55 PM
yes it is enable
and i also check the cleintLink
11-21-2011 11:02 PM
Click on your ap and dive into the radio is it enabled? See attached
11-22-2011 11:30 PM
Hi Bilal,
if your domain is Pakistan ..then you should get device from Cisco as regulatory domain -C..eg: AIR-CAP3502E-C-K9
thanks,
Anvar
11-22-2011 11:39 PM
Its a correction.....
sorry guys.... Regulatory domain is -C for Pakistan only with Standalone Access Points . and it is -E for Pakistan with all LWAPP APs.
again sorry for the miss lead..
Anvar
11-23-2011 08:20 AM
can any one guide me How i configure 5Ghz using b/g/n radio not in a/n.
i want to achive 300 Mbps.
thanks
11-23-2011 08:26 AM
Surendra
