11-21-2011 07:16 AM - edited 07-03-2021 09:06 PM
hello
i have bought cisco 892W router, i want to configure As Access point and connect two more 1142 Access points with this router.
i configure router and ap. but its not working. i am not getting ssid
please assist
current configuration of router AP as attachment.
thanks
vikas kumar
11-22-2011 12:17 PM
To broadcast the SSID you need guest-mode configured under the dott11 radio . Also WEP is hex, wpa or wpa2 pre shared you can do ASCII.
Sent from my iPhone
11-22-2011 01:05 PM
Hi scott,
i have configured AP 1142 and is working fine.
thanks so much for support and help.
i want to ask one problem, how can broadcast single SSID multiple APs
as i have one Cisco 892W router and 3 Cisco 1142 AP
i want to use same ssid and Auth Key for all APs
can you please assist
regards
vikas
11-22-2011 01:10 PM
Each AP will have to broadcast the SSID. Basically the configuration on the 1142 will be identical except for the ip address and host names. The channel should also be different. For the 2.4ghz, use either 1, 6 or 11.
Sent from my iPhone
