Configure AIR-AP1231G-A-K9 for WGB (IOS 12.4(13d)JA
I am trying to configure one of our extra 1231 AP as a work group bridge. The AP was configured as a lightweight AP so I think that might be part of my issue.
This was the documentation I found to do the config: http://cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43hot.html
However I do not have the commands available that they list.
Here is sh ver info:
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 08-Feb-08 17:24 by prod_rel_team
swn-e9-wh-01-SWAP#config t
Enter configuration commands, one per line. End with CNTL/Z.
swn-e9-wh-01-SWAP(config)#int dot
swn-e9-wh-01-SWAP(config)#int dot11Radio 0
swn-e9-wh-01-SWAP(config-if)#stati?
% Unrecognized command
Is this not possible with the IOS and AP that I have?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Configure AIR-AP1231G-A-K9 for WGB (IOS 12.4(13d)JA
Hi Eric,
I'm just curious, did you convert the AP back to IOS already?
This can be converted to an Autonomous/stand-alone AP that you desire;
Here is a conversion method;
Reverting the Access Point Back to Autonomous Mode
You can convert an access point from lightweight mode back to autonomous mode by loading a Cisco IOS Release that supports autonomous mode (Cisco IOS release 12.3(7)JA or earlier). If the access point is associated to a controller, you can use the controller to load the Cisco IOS release. If the access point is not associated to a controller, you can load the Cisco IOS release using TFTP.
Using a TFTP Server to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
Step 4 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 5 Disconnect power from the access point.
Step 6 Press and hold MODE while you reconnect power to the access point.
Step 7 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 8 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9 After the access point reboots, reconfigure it using the GUI or the CLI.
Hope this helps!
Rob
1 REPLY
Hi Eric,
Hope this helps!
Rob
4155
