Configure wireless on 891w router
Hi, looking for a steps to configure wireless part of 891w router - tried to follow installation wizard and got stuck to accessing BVI interface. The web page that is open when clicking on link in setup wizard presents only "Enter" button and that it is.
Could someone provide me with links to config info so i can configre wifi using good old CLI.
Thanks in advance.
1 ACCEPTED SOLUTION
Re: Configure wireless on 891w router
I have upgraded the AP IOS to ap801-k9w7-tar.124-21a.JY which has fixed the issue.
Thanks again!
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/wlan_ps380_TSD_Products_Configuration_Guide_Chapter.html
Its a software bug..
Please use the above doc to overcome the issue using the CLI and then i will let u know what to do to get the web access
Surendra
Hi Surendra,
i uploaded different IOS version that got me into GUI with no problem.
Thanks for you help.
Regards.
WOW!!! Thats great to hear have a great weekend... C ya.
Surendra
I am running into the same issue as the original poster.  I am running IOS ap801-k9w7-mx.124-21a.JA1 which shipped with the AP.
Is this a documented software bug, and if so is there a Bug ID that explains the fix?
endpoint: Which version of IOS did you upgrade to that fixed you issue?
Thanks.
Hi William,
The below link will provide you the detailed explanation along with the bug ID..
https://supportforums.cisco.com/docs/DOC-13047
Surendra
vinashar - Yes, I did check the doc which Surendra referenced earlier in this thread.  I posted in this thread because I found no reference to a GUI bug.  The section on Configuring Wireless Settings has a link to another article discussing configuration using a web broswer and that article was based on a different versio of IOS, but again, I found no mention of a GUI bug.
Surendra - Thank you, this is perfect!  I initially tried the alternative access method described in the Bug ID using the http:///ap_express-setup.shtml URL, and it works fine, although I will be updating the IOS shortly.
Thanks again!
5861
