Configuring 1602i Wireless Access Point without RADIUS
I just purchased my first Aironet 1600 Series Wireless Access Point and have run into an issue.
My product is the AIR-SAP1602I-A-K9 running system software 15.2(2)JB2
I'm attempting to configure this standalone unit without using a RADIUS server.  We are a small organization with only a handful of wireless users.
In the past, using the 1200 series and the 1140 series access points, I've been able to setup using WPA authentication and this has worked perfectly.  We would simply give the handful of users that are both outside consultants and internal employees the passphrase for the SSID and it worked perfectly.
I can't seem to discover how to do this using this newer system software.
I don't believe I should have to setup a radius server in order to use security with this access point since I have been able to setup the previous versions without.
Can anyone offer suggestions or a solution?
Re: Configuring 1602i Wireless Access Point without RADIUS
kaaftab your are a really assH* and stupid, anyone can copy and paste link!! If u dont want to help...just dont do it !!!
You info dosent help with the issue!
VIP Purple
How about something like below. This config is based on the following conditions & you can modify it according to your need. Try it & see
AP management : Vlan 999 (192.168.99.x/24)
Wirelss User : Vlan 143 (192.168.143.x/24)
SSID Name : TEST
PSK : Cisco123
Encryption : WPA2/AES
AP Connected to G1/0/11 of SW.
DHCP for wireless users defined on SW
Sample Switch Configuration
ip dhcp excluded-address 192.168.143.1 192.168.143.50
ip dhcp pool VLAN143
network 192.168.143.0 255.255.255.0
default-router 192.168.143.1
interface GigabitEthernet1/0/11
switchport trunk native vlan 999
switchport trunk allowed vlan 143,999
switchport mode trunk
interface Vlan143
ip address 192.168.143.1 255.255.255.0
interface Vlan999
ip address 192.168.99.1 255.255.255.0
Sample AP Configuration
dot11 ssid TEST
   vlan 143
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii Cisco123
   guest-mode
interface Dot11Radio0
ssid TEST
encryption vlan 143 mode ciphers aes-ccm
no shutdown
interface Dot11Radio0.143
encapsulation dot1Q 143
bridge-group 143
interface Dot11Radio0.999
encapsulation dot1Q 999 native
bridge-group 1
interface Dot11Radio1
ssid TEST
no shutdown
interface Dot11Radio1.143
bridge-group 143
interface Dot11Radio1.999
bridge-group 1
interface GigabitEthernet0.143
bridge-group 143
interface GigabitEthernet0.999
bridge-group 1
interface BVI1
ip address 192.168.99.99 255.255.255.0
ip default-gateway 192.168.99.1
If this does not work pls let us know, we can help to fix it.
Rasika
**** Pls rate all useful responses ****
2546
