Community Member
Configuring AIR-SAP2602E-E-K9 for Transmit/Receive Antenna
Any help on how we can ocnfigure the Transmit and Receive Antenna via CLI.
I am trying to configure left for receive and right to transmit and I have four antennas as it shows :
     Test_lab(config-if)#antenna ?
  a-antenna     use antenna A
  ab-antenna    use antennas A and B
  abc-antenna   use antennas A, B, and C
  abcd-antenna  use antennas A, B, C, and D
  gain          Configure Resultant Antenna Gain
The CLI link for 15.2(2)JA isnt matching it as per :
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Command/reference/cr12425d-chap2.html#wp3103507
Any suggestions?
-Thanks
That is for older AP, not for the newer ones.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hall of Fame Super Silver
I agree with Steve... there is no benifit for having one antenna recieve and the other transmit.  If you don't want to use all 4 and have diversity, then choose what you want to use.  IF you have two antenna's then choose:
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Community Member
Thanks Stephen/Scott for your inputs.
We have a requirement to do this now, but the command on interface dot11radio 0|1 show antenna command and selection of a,b,c or d.
I dont see any option to select either transmit or receive?
Is it supported on SAP2602 platform? I am running latest IOS 15.2(2)JA, is it supported on this? Is the keyword receive/transmit removed? Or any other command it needs?
-Thanks
Joe
Re: Configuring AIR-SAP2602E-E-K9 for Transmit/Receive Antenna
since each antenna is a radio, it should be tx/rx when you select a/ab etc.  no further command needed
HTH,
Steve
dont see the antenae config guide at cisco site  for autonomous AP but got the config for lightweight AP with WLc:-
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_010000110.html
1324
