Configuring AP 801 on Cisco Wireless router 861W
Hello
Wondered if any cisco experts can help me with this issue.
I've created two configurations. One for the router side and one for the AP point side. However, I am having trouble getting the internal AP to bridge to the router properly. It is my understanding that the Wlan-GigabitEthernet is the internal interface connecting to the AP and the BVI1 together.
I can't ping any ip address on the router side from the ap and the radio is active and we can see it but it seems that it doesn't give an ip address.
See below.
TestWifi#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       unassigned      YES NVRAM  up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  administratively down down
FastEthernet4              192.168.X.175   YES DHCP   up                    up
NVI0                       unassigned      NO  unset  up                    up
Vlan1                      192.168.43.1    YES manual up                    up
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
wlan-ap0                   192.168.43.1    YES TFTP   up                    up
On the AP side, this is what shows as follows.
ap#
ap#show ip int brief
BVI1                       192.168.43.2    YES manual up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
I can't help but wonder if it is a VLan issue or an ip issue but I could use a second opinion.
I've included both configurations. Can someone check if something is amiss?
Thanks in advance.
Everyone's tags (3)
1 REPLY
Bronze
I checked the configuration of the router and there are several things we need to change.
1. Since you have given the VLAN 1 an IP address it does not need to be linked to bridge group 1, so please do a no bridge group 1 under the VLAN 1 config t mode.
2. On the router side the BVI1 is not needed since it has an AP module, so please doe a no int BVI1 on the config t of the router.
3. Then since you configured the internal gig port as a trunk port, on this units we need to use the switchport trunk allowed vlan x,x  command allowing the VLANs needed between the AP and the router or if no VLANS needed then set the port back to a switchport access vlan 1.
Then on the configuration of the AP module since you have not configured VLANs then we do not need to use the mbssid under the radio or the SSID itself, so please remove it from the mbssid from the radio and on the SSID remove the mbssid guest mode and add the guest mode only.
1804
