Configuring tacacs on AP 1100
Hi, I'm trying to configuring an AP to be administrated using a tacacs server.
Via telnet I do not have problems authenticating but when I try to acces Via HTTP level 1 acces no problem but level 15 acces I can not authenticate.
Thanks a lot
This is my run
Building configuration...
Current configuration : 2363 bytes
! Last configuration change at 09:42:58 GMT Mon Feb 20 2006 by penalh
! NVRAM config last updated at 09:20:16 GMT Mon Feb 20 2006 by Cisco
version 12.2
no service pad
service password-encryption
hostname ew-plcprueba
enable secret xxx
username Cisco password xxx
clock timezone GMT -4
ip subnet-zero
no ip domain lookup
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid prueba
authentication open
guest-mode
infrastructure-ssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
rts threshold 2312
station-role root
ew-plcprueba#config t
Enter configuration commands, one per line. End with CNTL/Z.
ew-plcprueba(config)#no username Cisco password 7 072C285F4D06
ew-plcprueba(config)#exit
ew-plcprueba#sh run
Current configuration : 2324 bytes
! Last configuration change at 09:43:27 GMT Mon Feb 20 2006 by penalh
version 12.2
no service pad
enable secret xxx
ip subnet-zero
no ip domain lookup
aaa new-model
bridge irb
no ip address
no ip route-cache
ssid prueba
authentication open
guest-mode
infrastructure-ssid
54.0
rts threshold 2312
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip addressxxx.xxx.xxx.xxx 255.255.255.0
no ip route-cache
ip default-gateway 167.175.xx.xx
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
/ivory/1100
ip http authentication aaa
ip radius source-interface BVI1
snmp-server community xx RO
snmp-server enable traps tty
tacacs-server host xxx.xxx.xxx.xxx single-connection
tacacs-server directed-request
tacacs-server key cisco1
radius-server authorization permit missing Service-Type
bridge 1 route ip
line con 0
line vty 0 4
transport input telnet
line vty 5 15
ntp server
end
Silver
Re: Configuring tacacs on AP 1100
Tacacs on AP is known to have many issue. I would suggest that you configure RADIUS servers for Access Points. This will work fine and will be very secure.
I managed to get this to work by creating a new user on the ACS that authenticated to the Cisco Secure Database. However, when attempting to process the login via ACE it did not like it one bit... It does'nt help if your already using Radius to authenticate CKIP
and you try to authenticate the login to... anyone have any ideas on this one...
183
