Configuring Wireless on Cisco 878
Sorry, if already asked...
I try to config Wireless on Cisco 878...
I want that switch ports be in one VLAN with Wireless port... and Wireless client be in one ip subnet with LAN clients...
I use following instructions
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d289.html#wp999748
my config is:
bridge irb
interface Dot11Radio0
no ip address
ssid cisco
vlan 1
interface Vlan1
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
interface BVI1
ip address 192.168.0.1 255.255.255.0
BVI int is up, protocol is up but i can't ping 192.168.0.1 not from Wlan and LAN...
What methode can I use to configure router for my task?
Thank you very much...
Silver
Re: Configuring Wireless on Cisco 878
For this all you need to do is have a single VLAN on the wireless router and configure the switch native vlan as the same vlan as the router. This will work.
Sorry, but can you type recomended commands?
282
