confusion on transmit power
hi
im reading the data sheet of my access point and am a little confused
"Transmit power @ normal temp range for FCC:
802.11b: 16 dBm @ 1TX, 19 dBm @ 2TX, 20.5 dBm @ 3TX
802.11g: 13 dBm @ 1TX, 16 dBm @ 2TX, 17.5 dBm @ 3TX
802.11n: 17 dBm @ 1TX @ MCS0~5/8~13, 13 dBm @ 1TX @ MCS6/14"
i basically understand everything except "@ 1TX" or "@ 3TX". what's a "TX"?
thank you
markus
1 ACCEPTED SOLUTION
Re: confusion on transmit power
Tx should be Transmitter. Like Rx is Receiver.
1Tx means one antenna, 2Tx means two antenna.  There are no 3rd transmitter out yet I believe.
However you have 3 Rx.
Hope it helps.
Brendon
Hope it helps.
Brendon
makes sense to me now. thanks brendon
Hi Brendon,
I don't know what those TX means. However, in 11b and 11g there is no way to have more than 1 transmitter. Even a 1242 with 2 antennas in diversity, there is only 1 antenna transmitting at a time, so I'm suspicious that this would be the meaning.
Only in 11n, you have 2 antennas transmitting at the same time, and no 3 yet.
Nicolas
259
