connect air-sap-1602i-e-k9 to wlc 2504
not able to connect this AP´s to wlc 2504 with 7.4.121
Ap gets an dhcp but does not show up in controller never!
nothing happens on controller side. Below is a shot of AP booting process...
Could you help?
"ap boot":
Boot from flash
IOS Bootloader - Starting system.
FLASH CHIP: Spansion S25FL256
Xmodem file system is available.
flashfs[0]: 181 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31936000
flashfs[0]: Bytes used: 10419200
flashfs[0]: Bytes available: 21516800
flashfs[0]: flashfs fsck took 10 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: c0:8c:60:29:9b:92
************* loopback_mode = 0
Loading "flash:/ap1g2-k9w7-mx.152-2.JB2/ap1g2-k9w7-mx.152-2.JB2"...#############                             ################
File "flash:/ap1g2-k9w7-mx.152-2.JB2/ap1g2-k9w7-mx.152-2.JB2" uncompressed and i                             nstalled, entry point: 0x100000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(2)JB2, RELEASE S                             OFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 12:16 by prod_rel_team
Initializing flashfs...
flashfs[3]: 181 files, 7 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31808000
flashfs[3]: Bytes used: 10419200
flashfs[3]: Bytes available: 21388800
flashfs[3]: flashfs fsck took 9 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8764B 8000 0 A8000000 A8010000 0
Rate table has 180 entries (48 SGI/72 BF variants)
Radio1  present 8764B 8000 0 88000000 88010000 4
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1602I-E-K9    (PowerPC) processor (revision B0) with 98294K/32768K                              bytes of memory.
Processor board ID FGL1738W5CE
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C0:8C:60:29:9B:92
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17374RRW
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1738W5CE
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP1602I-E-K9
utoconfig enabled device!!!
*Mar  1 00:00:17.067: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:18.067: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:01:03.923: Starting Ethernet promiscuous mode
*Mar  1 00:01:03.995: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:01:03.995: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Mar  1 00:01:04.007: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
*Mar  1 00:01:04.007: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:01:04.039: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:01:04.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:01:04.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:01:04.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:01:13.091: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.50.2.174, mask 255.255.0.0, hostname ap
VIP Purple
Re: connect air-sap-1602i-e-k9 to wlc 2504
Your AP have autonomus image.
To connect with WLC you need to to convert this AP to LAP.
Reagrds
HI
How can that be done?
VIP Purple
Check this :
  • k9w7 - autonomous (or "site survey") IOS
  • k9w8 - full lightweight IOS (this is what is bundled in the WLC .aes image, and is factory installed on "mesh" APs)
  • rcvk9w8 - lightweight recovery image - this is factory installed on lightweight APs, unless a "mesh" image is specified; it lacks radio firmware
You need k9w8 image on AP.
How to convert to LAP.
For the LWAP conversion, use the recovery image ( e.g  -rcvk9w8-tar.).  use the command on the autonomous AP priviledge mode.
AP#archive download-sw /force-reload /overwrite tftp://10.10.10.1/c1600-rcvk9w8
or
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
ok have the file, the tftp
password for enable on ap ?
Cisco is making it tuff!
VIP Purple
Password is : Cisco
Enable password is also : Cisco
C, first later is capital.
make sure that u have recovery image.
is it possible to change IP address of the AP?
it gets dhcp but then loses the ping it after the boot
VIP Purple
did you changed the AP to Lightweight ??
Here are the commands:
AP#capwap ap ip address
AP#capwap ap ip default-gateway
AP#capwap ap controller ip address
AP#capwap ap hostname
Hi Sorry ,
I did not yet changed because i loose connectivity when ap boots
archive download-sw /overwrite /force-reload tftp://10.50.2.179/ap1g2-rcvk9w8-tar.152-4.JB3.tar
My PC is dhcp on 10.50.2.179 and ap is 10.50.2.174..
But in the middle it looses connectivity and i cant run fully the extracting...
VIP Purple
Try to change the image as per my last posts links.
Let me know the outcome.
If you face any problem then please write back here.
But can´t I change the IP  of the AP to static just for the conversion ?
AP config ??
VIP Purple
HI,
Resetting to Default Settings Using the MODE Button
Follow these steps to reset the access point to factory default settings using the access point MODE button:
Step 1 Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2 Press and hold the MODE button while you reconnect power to the access point.
Step 3 Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
follow this posts:
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
1827
