Connect Cisco lwapp to Controller in DMZ ?
hi,
i have lwapp 1130 in internal network , i already configure dhcp with option 43, in my switch connected to ap i set vlan 1424 for management AP and the ap got ip addres from dhcp server. The wlc controller is in DMZ with ip 10.222.5.3, from switch connected to ap i can ping 10.222.5.3 , it aslo seperated by cisco asa firewall, i already set allow from 0.0.0.0 to 10.222.5.3 udp port 5246-5247 and 12222-12223.
but i dont see my lwapp join the controller
thx
Everyone's tags (3)
1 ACCEPTED SOLUTION
Salam Ibrahim,
You can collect the following to isolate:
-From AP: Console output.
- From WLC:
   >debug capwap events enable
   >debug capwap errors enable
If your DHCP is behind the firewall then make sure to allow dhcp traffic on the ACL.
Make sure your option 43 configuration is correct.
Amjad
Rating useful replies is more useful than saying "Thank you"
Salam Ibrahim,
- From WLC:
Amjad
Hall of Fame Super Silver
Re: Connect Cisco lwapp to Controller in DMZ ?
You can console into that LAP and issue: capwap ap controller ip address 10.222.5.3
If something is blocking, your ap will not join. Also the output from the console will tell you some good info also.
Why do you have the wlc in the dmz?
-Scott
This is the error from lwapp
*Aug  8 05:23:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip:
10.222.5.2
peer_port: 5246
*Aug  8 05:23:26.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Aug  8 05:23:48.209: %CDP_PD-4-POWER_OK: Full power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Aug  8 05:23:48.248: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Aug  8 05:23:48.286: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Aug  8 05:23:49.209: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Aug  8 05:23:49.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Aug  8 05:23:56.001: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Aug  8 05:23:56.001: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for
10.222.5.2
is reached.
*Aug  8 05:24:25.999: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to
10.222.5.2
:5246
suddenly i realize i set the wrong wlc controller management and routing and some acl, the lwapp contact wlc ip
10.222.5.2 but is set in the network and dhcp 10.222.5.3. now it works
thx
Glad that it is now working
488
