Connecting WLC 2504 and AP1242
Dear All
Greetings
I am new guy in Cisco Wireless and i want to connect Ap1242 and WLC 2504.ON WLC under Wireless it is not showing Connected AP.
Please share some Network diagram or Example regarding this
Inititally i Made some some CLI in AP
version 12.4
no service pad
service password-encryption
hostname GPC-PLANT
enable secret 5 $1$6GdJ$TuYeZxYvymPL03a46JWtQ0
no aaa new-model
dot11 ssid GPC-PLANT
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid GPC-PLANT
channel least-congested 2412 2437 2462
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.3.48 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
and ON WLC2504
Enter Administrative User Name (24 characters max):
Invalid response
Enter Administrative User Name (24 characters max): admin
Enter Administrative Password (3 to 24 characters): ********
Re-enter Administrative Password                 : ********
Management Interface IP Address: 192.168.3.49
Management Interface Netmask: 255.255.255.0
Management Interface Default Router: 192.168.3.1
Management Interface VLAN Identifier (0 = untagged):
Management Interface Port Num [1 to 4]: 1
Management Interface DHCP Server IP Address: 192.168.3.1
Virtual Gateway IP Address:
Invalid response
Virtual Gateway IP Address: 1.1.1.1
Mobility/RF Group Name: GPC-PLANT
Network Name (SSID): GPC-PLANT
Configure DHCP Bridging Mode [yes][NO]: N
Invalid response
Invalid response
Configure DHCP Bridging Mode [yes][NO]: no
Allow Static IP Addresses [YES][no]: no
Configure a RADIUS Server now? [YES][no]: no
Warning! The default WLAN security policy requires a RADIUS server.
Please see documentation for more details.
Enter Country Code list (enter 'help' for a list of countries) [US]: KSA
Invalid Country Code - enter 'help' for list
Enter Country Code list (enter 'help' for a list of countries) [US]: help
Enter the country code list (e.g. US,CA,MX) max=20.
Supported Country Codes:
AE, AL, AR, AT, AU, BA, BE, BG, BH, BO, BR, BY, CA,
CA2, CH, CL, CM, CN, CO, CR, CY, CZ, DE, DK, DO, DZ,
EC, EE, EG, ES, FI, FR, GB, GI, GR, HK, HR, HU, ID,
IE, IL, ILO, IN, IQ, IS, IT, J2, J3, J4, JO, JP, KE,
KR, KN, KW, KZ, LB, LI, LK, LT, LU, LV, MO, MC, ME,
MK, MT, MX, MY, NL, NO, NZ, OM, PA, PE, PH, PH2, PK,
PL, PR, PT, PY, QA, RO, RS, RU, SA, SE, SG, SI, SK,
TH, TN, TR, TW, UA, US, US2, USL, USX, UY, VE, VN,
ZA
Enter Country Code list (enter 'help' for a list of countries) [US]: SA
Enable 802.11b Network [YES][no]: yes
Enable 802.11a Network [YES][no]: yes
Enable 802.11g Network [YES][no]: yes
Enable Auto-RF [YES][no]: yes
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Connecting WLC 2504 and AP1242
C1240 Software (C1240-K9W7-M), Version 12.4(10b)JDA3,
1.  The IOS your 1240 is running is an autonomous image.  You need to copy the controller-based image ("RCV") into the AP and boot that image.
(Cisco Controller) >show time
Time............................................. Thu Jul  4 02:37:49 2013
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval.........................     86400
Index     NTP Key Index     NTP Server      NTP Msg Auth Status
Highly recommended that you configure NTP on your WLC.  In case the WLC reboots and NTP is not configured, your APs will not join until the correct time and date is configured.
Hall of Fame Super Silver
Just to add.... You need to be able to download the recovery image from CCO. If you don't have a valid support contract that allows you to download the rcv image for the 1242, then you are out if luck, as that AP will never join the WLC 2504. Of you are able to download the rcv image, here are some links to show you have to convert your autonomous ap to a lightweight ap.
Using a TFTP Server to Return to a Previous Release
https://supportforums.cisco.com/docs/DOC-18268
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
Gold
Hi Muhammed,
It looks like you have got a an autonomous access point. These access point will not get register to WLC. You need a Light Weight access (LWAP) point to see them on WLC.
You can convert this autonomous AP to LWAP by following the process below.
Download the LWAPP image for your AP from the Cisco website and get the console access the AP and just issue the command..
archive download-sw/overwrite/force-reload tftp:////
For example the command would look like as below
AP#archive download-sw /force-reload /overwrite tftp://10.0.0.5/c1140-rcvk9w8-tar.124-23c.JA.tar
You should TFTPd32 downloaded from Google and in the TFTPd32 pointing to the image
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
Post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh inventory; and
5.  AP:  sh ip interface brief
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(10b)JDA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 07-Jun-09 04:13 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
GPC-PLANT uptime is 3 hours, 11 minutes
System image file is "flash:/c1240-k9w7-mx.124-10b.JDA3/c1240-k9w7-mx.124-10b.JDA3"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1242AG-E-K9    (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1705807R
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:06:F6:70:84:0C
Part Number                          : 73-13786-01
PCA Assembly Number                  : 800-37049-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC17023DMR
Top Assembly Part Number             : 800-29233-03
Top Assembly Serial Number           : FCZ1705807R
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1242AG-E-K9
Configuration register is 0xF
NAME: "AP1240", DESCR: "Cisco Aironet 1240 Series (IEEE 802.11a/g) Access Point"
PID: AIR-AP1242AG-E-K9 , VID: V05, SN: FCZ1705807R
Interface                  IP-Address      OK? Method Status                Prot   ocol
BVI1                       192.168.3.48    YES other  up                    up
Dot11Radio0                unassigned      YES unset  up                    up
Dot11Radio1                unassigned      YES unset  reset                 down
FastEthernet0              unassigned      YES other  up                    up
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_b3:ad:04
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.3.49
Last Reset....................................... Power on reset
System Up Time................................... 0 days 3 hrs 6 mins 9 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
--More-- or (q)uit
Next Boot License Type........................... Permanent
Configured Country............................... SA  - Saudi Arabia
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +28 C
External Temperature............................. +34 C
Fan Status....................................... 3900 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 84:78:AC:B3:AD:00
Maximum number of APs supported.................. 5
NTP Servers
NTP Servers
-Scott
Thanks all.
It is working fine,Really awesome Repy from your side
but I need to install One AP to Switch with Switch having VLAN30 .
and One should Connected to a Normal switch ,
CORE Swtich---Distribution Switch--gig1/0/2--> Switch with VLAN 30
Core Switch-----Distrubition Switch(gig1/0/1 with IP 192.168.30.1) ----Access Switch----WLC and AP
Should I connect all AP to WLC or Connect to AP to some where else ?
Connect all your APs to your switch.  Your switch connects to your WLC.
Dear Leo Laohoo and Scott Fella
I am not getting Ip address from the AP or WLC or Switch although Switch has DHCP pool and if I connects machine to Port of Switch,I am getting IP.
Please guide me what i need to change from AP/WLC
AP 192.168.3.49 /24 GW: 192.168.3.1
WLC 192.168.3.48/24 GW 192.168.3.1
ip dhcp excluded-address 192.168.3.1 192.168.3.50
ip dhcp excluded-address 192.168.3.201 192.168.3.254
ip dhcp pool STORE1-192.168.3.0
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   dns-server 192.168.1.1 192.168.1.5
That's not right.
Your DHCP pool "STORE1", subnet 192.168.30/24, only gives an IP Address to your APs.
If you want to a DHCP pool for your wireless clients, then you need to create a new pool.
Switch:
ip dhcp  exclude 192.168.4.1 192.168.4.50
ip dhcp pool client
network 192.168.4.0 /24
default-route 192.168.4.1
dns-server BLAH
vlan 100
name Client
interface vlan 100
no shutdown
ip address 192.168.4.1 255.255.255.0
Ok, now you need to create a new dynamic interface (VLAN 100) with the following subnet.  Tie your client SSID to that Dynamic Interface.  And don't forget to allow the client VLAN (VLAN 100) in your allowed-vlan from the switch.
2869
