Community Member
connection between cisco WLC 2106 and cisco 2960 switch
I am having set-up with WLC 2106 and switch 2960 switch from where AP 1131 will be connected. I am getting confused with phisical connectivity and configuring the ap manager  ip and management ip as well DHCP pool for AP and client in WLC 2106.
How do I connect wlc 2106 and switch 2960 and configure the 2106.
I would appreciate to get the proper answer.
Gold
Re: connection between cisco WLC 2106 and cisco 2960 switch
The 2106 should only have 1 physical connection to the network.  The managmenet, ap-manager, etc interfaces are logical interfaces.
https://supportforums.cisco.com/docs/DOC-11760
Community Member
Shouldn't you be able to set it up so that different ports serve different interfaces?  Example: mgmt--> port 1, vlan10---> port 2, vlan 20 ---> port 3?  If you only used one port I could see a bottleneck occuring with 25 APs connected to a single 100mbps port.  I just checked my lab setup and it works fine using multiple ports for different vlans, mgmt, and ap-mgmt interfaces.
1117
