Connectivity between 5508 and cisco 4507 switch
I have 5508 WLC which i want to connect to cisco 4507 switch.configure the same port as a trunk.
And i could see that , compare to other WLC , this 5508 product has got some other parameters and some what different to configure.
I am confused to configure 4507 port configuration which will be connected to WLC.
As i understood , I can configure below commands for get connectivity with WLC 5508
4507 switch ( config ) # interface gig 1/1
                                   switchport mode trunk
                                    switchport trunk encapsulation
                                    switchport trunk allowed vlan ...... ( no. )
                                    no shut
and to configure DHCP ip pool for AP , below commands to be configured
   4507 switch (config) # ip dhcp pool ..name of pool ...
                                   network  192.168.10.0 255.255.255.0
                                   default router 192.169.10.1
                        (config) # vlan 10
                                    # name management
                        (config) #interface vlan 10
                                     ip add 192.168.10.1 255.255.255.0
                                     no shut
Please suggest me if i am wrong or whether i need to put some more commands in 4507 switch.
and about WLC 5508
how do i configure management interface and AP -manager interface along with IP address ( take example ) and in 5508  , AP - manager interface is an optional.
Please share initial configuration for WLC as well 4507 switch.
answer would be appreciative.
  • Getting Started with Wireless
Re: Connectivity between 5508 and cisco 4507 switch
The configuration on the switch looks good... make sure the native vlan is specified and allowed between the WLC and the switch..
The controller config..
Cisco 5500 Series Controllers, the management  interface acts like an AP-manager interface by default.
command to assing the ip for management.. is same as any other controller..
config interface address management <gateway>
Lemme know how this answered your question!!
Surendra
Bronze
What is your endgame?  Are you just trying to get your 5508 on the network using the management interface or are you trying to config
ure multiple interfaces for different wlans?  It's going to change how you approach your wlc interface configuration.
In my case, we have multiple interfaces (internal wireless and guest wireless) using different interfaces and vlan identifiers.
If you have a small deployment planned, you can always point everything to the management interface, though I don't recommend it.
As your users get used to using the wireless, the need will grow and you'll have to re-do it.
Get your hands on Cisco's 5500 configuration guide:
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70ovrv.html
It will detail how to configure wlc interfaces (including virtual interfaces for web auth).
Ven
Ven Taylor
Thanks for showing interest in my query.
My endgame is :
To achieve connecitvity WLC to  two different 4507 chassis  ( Switch 1 & Switch 2 ) which are configured with HSRP.
More details :
1) I have 10 3502i access points , 5 will be connected to switch 1 thourgh POE switch and another 5 will be connected to switch 2 ( Switch 1 & 2 are configured with HSRP / with two stanby group : so that i can achieve active/active redundancy )
2) WLC connectivity will be
    WLC port 1 ( 1 gig port ) : gig 1/1 sw1 ( 4507 switch )
     WLC port 2 ( 1 gig port ) : gig 1/1 sw2 ( 4507 switch )
3) sw1 and sw2 , both are configured for HSRP redundancy ( two standby groups are created to achieve active/active redundancy )
challage i am facing :
configuration of wlc 5508
interface configuration :
Management interface : Usually map with one physical port if you have only one physical but in this scenario , I have two physical interface ( port 1 & port 2 ) to two different 4507 chassis .
  do i need map other port as a back-up port ?
Please light on this ?
AP-manager interfcae is optional but in this scenario , i believe , i need to go ahead to configure multiple AP-manager interface to divide the ap traffic in between two 4507 chassis ?
Please correct me if i am wrong .
what about other interface which will have problem to map with these two physical ports ?
Please find attached diagram for more details ?
Please suggest me for the same.
You're pretty much correct. If you split the WLC between 2 switches, you need to configure a backup port for the management, have an ap manager for each port you connected the WLC to. The client interfaces will have to be manually assigned to ports.
Problem with this is that a perfect load balancing is not achieved. LAG is the only way to do that (but only on one switch). If that's redundancy that you want, then you should be served.
Nicolas
Don't forget to rate answers that you find useful
1155
