controller and APs upgrade??
I have a set of APs and I need to buy a controller for them. please see the specification below:
Product/Model Number: AIR-AP1232AG-E-K9
Top Assembly Serial Number: FCZ1032Z022
System Software Filename: c1200-k9w7-tar.123-8.JA2
System Software Version: 12.3(8)JA2
Bootloader Version: 12.3(2)JA4
I am planning to install the 4404 WLAN controller.
do I need to make any upgrade to the software used by the APs?
thank you.
hassine laribi
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
Re: controller and APs upgrade??
You need two things:
1.  You need to prepare the LWAP image to convert your autonomous AP (aAP) to light-weight AP (LWAP); and
2.  You need to use the Cisco Upgrade Tool to convert your aAP to LWAP.
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
LWAPP Upgrade Tool Troubleshoot Tips
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml
Hope this helps.  May I request if you can rate my post if this is helpful?  Thank you very much.
323
